cpu utilization.
ilnaiduccna
Hi Experts,
Can any body clearly explain about cpu utilization that how we will caliculate and what are points we should look when calculating cpu utlization.
Below I am pasting one router cpu utilization.
Router1#sh processes cpu history
3222222222233333333333333333333333333333333333333333333333
1999999999922222222223333311111222222222200000111110000000
100
90
80
70
60
50
40
30 ************************************************************
20 ************************************************************
10 ************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
3333333333333322322232222322322333333333323333322222222233
0333335313100198187809788099198210344200080000087965013400
100
90
80
70
60
50
40 *
30 #################*###**#######*#######*##*#####**#** ####
20 ############################################################
10 ############################################################
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
3342312112255555555555555565544454555555555555555565544445455555556555
4319572563334566732234543354986816124775321233454224767654824766244584
100
90
80
70 *
60 **** * * * *** * * * *** *** **
50 **####***######**********######*########*********############
40 * * *############################################################
30 #**** #############################################################
20 ###********#############################################################
10 #####****###############################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Naidu.
aijaz802
Hi Naidu,
I'm explaining the first graph details..which is last 60 sec history...
Y-axis is for CPU utlization..
X-axis is the time in seconds...which is you can read the columns as 0sec,5 sec, 10sec,15 sec...pls note the values are in vertical for 10 sec its 1 and below is 0...for 35th sec..its 3 and below is 5..
Please check the values again the switch/router..as the alignment of values posted here is gone.
The top two columns denote the maximum cpu utlized...in seconds graph..its 31%...read vertically..
in 60 minutes its 30%, in 72 hrs..its 34%..
I hope u understood it...you can go thru the following link for detailed explanation.
http://www.cisco.com/warp/public/63/showproc_cpu.html
Please rate if it helps..
*aijaz*
