Same Static IP assignment to any machine connected to a switchport......!
gauravshar
Level 2
Level 2
Is it possible to bind static IP's to particular ports so that any machine that plugs in will be assigned the same IP? How could this be accomplished?
--gaurav
spremkumar
Level 9
Level 9
hi
AFAIK you can bind an ip address based on the mac address of the pc instead of switchport.
But you can make sure that you get ip alloted from a particulat vlan range based on the vlan id configured on the switch port.
regds
But my requirement is :
any device PC/Laptop/printer must get the same IP everytime it is connected to that switchport. meaning is let us say : on day 1, if i have a printer connected to that port, the ip to printer should be 10.15.201.201 and when on second day if i have a pc connected to that port it should have ip 10.15.201.201
as of now, I do not know why does my client need this scenario.
--gaurav
Gaurav, would these devices connect to a L3 switch?
-Vaibhav
Ignore my previous question..Looks like the only option is to do manual bindings (provided you have limited devices ofcourse).
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiad_c/ch10/hipdhcps.htm#wp1074511
-Vaibhav
