11-06-2006 02:28 AM - edited 03-05-2019 12:38 PM
On one of my Cisco 2611XM which was working properly, i have one problem: It restarting all the time after IOS loading.
Please find attach the log below.
Could somebody tell me if it's a software or hardware problem?
regards
11-06-2006 02:38 AM
Please note the message that also shows up in the bootlog: "System received a Bus Error exception".
After reading this, I am afraid that you have a hardware issue. To troubleshoot, please remove all modules & WICs from the router. When it boots fine after this, the cause is likely in one of the modules. If not, it is likely the router's mainboard.
Leo
11-06-2006 02:40 AM
Hi ,
Can i know the image name which you are using ? I have seen trace back in logs and am going to decode the trace back.For that i need to have exact image which is there in router.After decoding the trace back we can come to conclusion.
satish
11-06-2006 02:42 AM
Hi Friend,
Have you installed 32MB flash? have you also loaded new bootrom?
Ankur
11-06-2006 02:53 AM
I have 2 router 2611XM with the same hardware config.
One my faulty router i just upgrade the IOS image to be conform with the other one. regarding the bootprom it's the same that the other one.
please find the interrogation of the other router (same software and hadware version).
11-06-2006 03:02 AM
Hi ,
I have decoded the trace back and you are hitting CSCeg06349.i.e 2611XM: NM-1E fails to boot after upgrade to 12.3(10)
Following is the decode of trace back.
0x801243D0:xilinx_config_read(0x80124390)+0x40
0x80123898:pci_bridge_config_read(0x80123860)+0x38
0x80123078:pci_config_read(0x80123050)+0x28
0x800AA64C:pa_amdp2_4e__analyze_pa(0x800aa5c4)+0x88
0x80120B38:pas_analyze_interfaces(0x80120854)+0x2e4
0x80120C1C:pas_subsys_init_class(0x80120bf8)+0x24
0x80DD04B8:subsys_init_class(0x80dd0390)+0x128
0x806C5614:system_init(0x806c53e0)+0x234
0x806C5808:init_process(0x806c57c4)+0x44
0x80479E70:ppc_process_dispatch(0x80479e4c)+0x24
0x8047D3A8:process_execute(0x8047d1f4)+0x1b4
It is problem with NM-1E.
Details of the bug is : Customer upgraded 2611XM to 12.3(10) (c2600-ik9o3s-mz.123-10.bin). Post the upgrade the router constantly crashed at bootup when the NM-1E was inserted. The customer mentioned the problem does not occur in 12.3(9b). The same NM-1E also works fine in a 2610 running 12.2T code
So it is better remove the card from router and try to insert new card.
Hope it helps you.
satish
11-06-2006 03:06 AM
OK,
thanks for your fast answer.
But, I maybe stupid but what is the card NM-1E?
11-06-2006 03:09 AM
NM1E is a one port ethernet network module.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8c.html
-amit singh
11-06-2006 03:11 AM
Hi Max,
Just remove the card from your router and see if it boots fine. If that's case then it is the problem with the card. As already posted by Satish, try some other IOS version as per the flash and dram on your router.
-amit singh
11-06-2006 03:15 AM
Hi ,
Can you paste sh diag of the router so that we can see what type of cards are installed in router ?
11-06-2006 03:02 AM
Hi Max,
Can you please update which image you were running before you started upgrade on this router?
Ankur
11-06-2006 03:14 AM
Hi Max,
AFAIK you sould upgrade IOS to one of the following releases 12.1.3T, 12.1.5T, 12.1(5)XM, 12.1(5)YB2, 12.2T, 12.2 , because support for 32 MBFlahs was first introduced in those releases. After the flash will be recognized you can download any image you need.
So you can see if replacing the card helps you or not and if not then try the IOS mentioned above and then upgrade to the one you want.
Ankur
11-06-2006 07:59 PM
11-06-2006 08:53 PM
No you dont have to change the IOS unless you are looking for some new software feature or some new hardware for the router.
HTH, Please rate if it does.
-amit singh
