CRC errors on cisco switch
Srinivas N
Level 4
Level 4
Dear All,
One of my wi-fi site having 2nos cisco 2950 switchs. in that network some D-link unmanageble swithes also there
and access points also connected to cisco switchs and D-link switchs.
after one or two days i am not able to connect the wi-fi, then i need to restart the access point then only wi-fi is working fine.
I upgraded the latest ios also.
I connected some access points to the cisco switch ports, those ports are showing crc error messages like below.
145 input errors, 144 CRC, 1 frame, 0 overrun, 0 ignored
and log file also show some errors like below.
000186: Jun 23 03:44:01: %SYS-5-CONFIG_I: Configured from console by vty0 (115.1
19.187.45)
000187: Jun 23 05:44:36: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
ernet0/5, changed state to down
000188: Jun 23 05:44:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
ernet0/5, changed state to up
000189: Jun 23 06:38:19: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000190: Jun 23 06:38:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000191: Jun 23 06:38:25: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
000192: Jun 23 06:38:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEth
what could be the problem,
I updated the lates IOS and changed the RJ45 connector both side.
Plz help on this.
Srinivas. N.
Thanks & Regards,
Srinivas.
18 Replies 18
Leo Laohoo
Kindly post the output to the following commands:
1.  sh run int f 0/5;
2.  sh contr e f 0/5
3.  sh interface f 0/5
Srinivas N
Level 4
Level 4
Hi leolaohoo,
Thanks for reply and plz find the sataus.
GP_VIZAG_MAINSW_2950#sh run int fa0/5
Building configuration...
Current configuration : 122 bytes
interface FastEthernet0/5
description * Back Side-I (Proxim) *
switchport access vlan 10
switchport mode access
end
GP_VIZAG_MAINSW_2950#sh cont
GP_VIZAG_MAINSW_2950#sh controllers e
GP_VIZAG_MAINSW_2950#sh controllers ethernet-controller  fa0/5
  Transmit                                Receive
4111734682 Bytes                        800406706 Bytes
   5324004 Frames                         3132634 Frames
    723276 Multicast frames                   167 FCS errors
    411370 Broadcast frames                 51740 Multicast frames
         0 Pause frames                     21924 Broadcast frames
         0 Single defer frames                  0 Control frames
         0 Multiple defer frames                0 Pause frames
         0 1 collision frames                   0 Unknown opcode frames
         0 2-15 collisions                      1 Alignment errors
         0 Late collisions                      0 Length out of range
         0 Excessive collisions               122 Symbol error frames
         0 Total collisions                 61932 False carrier errors
         0 Control frames                       0 Valid frames, too small
         0 VLAN discard frames                  0 Valid frames, too large
         0 Too old frames                       0 Invalid frames, too small
         0 Tagged frames                        0 Invalid frames, too large
         0 Aborted Tx frames                    0 Discarded frames
  Transmit and Receive
   1355392 Minimum size frames
   2785635 65 to 127 byte frames
    930782 128 to 255 byte frames
    291326 256 to 511 byte frames
    284047 512 to 1023 byte frames
   2809456 1024 to 1518 byte frames
         0 1519 to 1522 byte frames
GP_VIZAG_MAINSW_2950#sh int
GP_VIZAG_MAINSW_2950#sh interfaces fa0/5
FastEthernet0/5 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0012.00fe.d6c5 (bia 0012.00fe.d6c5)
  Description: * Back Side-I (Proxim) *
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 100BaseTX
  input flow-control is unsupported output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Last clearing of "show interface" counters 2d02h
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     1902845 packets input, 534271423 bytes, 0 no buffer
     Received 42355 broadcasts (28994 multicast)
     0 watchdog, 28994 multicast, 0 pause input
     2943416 packets output, 2240492645 bytes, 0 underruns
Thanks & Regards,
Srinivas.
Ok, good.
Your line errors are mostly coming from FCS and Symbols.
Mostly, this is attributed due to faulty cabling.
What do you mean by this?
Are you using a factory pre-terminated patch cables or did you crimp them yourself?
Thanks for quick reply,
what is meangin of FCS and symbols?
The cat cable is about to 70mts and i my self crimped the connectors.
Thanks & Regards,
Srinivas.
Test the cables with a TDR meter.
Hi Leolaohoo,
After reclimping the RJ45 connetors and clear the counter.
Now that port status like below
GP_VIZAG_MAINSW_2950# sh controllers e f0/5
  Transmit                                Receive
880211912 Bytes                        342010269 Bytes
   1214521 Frames                          913135 Frames
    139288 Multicast frames                     0 FCS errors
     96737 Broadcast frames                  5471 Multicast frames
         0 Pause frames                      2198 Broadcast frames
         0 2-15 collisions                      0 Alignment errors
         0 Excessive collisions                 0 Symbol error frames
         0 Total collisions                   134 False carrier errors
    406912 Minimum size frames
    681005 65 to 127 byte frames
    205184 128 to 255 byte frames
     63193 256 to 511 byte frames
     82091 512 to 1023 byte frames
    689271 1024 to 1518 byte frames
now advice me,...
Thanks & Regards,
Srinivas.
Looks good to me.  FCS and Symbol errors are "0", no collisions.
what about the
no problem?
Thanks & Regards,
Srinivas.
No problem?  Are you looking for one?  Because with all the counters I am sure you can find one if you look hard enough.
My boss once told me there was no such thing as a perfect design, I disagreed...I said "What about Holly Madiison, now thats a perfect design ".  I am just saying lol!
Moving on ....  Check out:
https://supportforums.cisco.com/thread/157286
and from Ciscos site:
The number of occurrences in which the interface detects a false carrier when frames are not sent or received.
IMO, while I have not seen this type of error before, you are seeing speed/duplex mismatches disguised as false carrier or a  pure layer one issue.
I'm with Jimmy.  I have never seen this line error before.  I didn't miss this.
Keep an eye on the counter.  If the counter goes up, by 50%, daily then you have a problem.
As of now the fales carrier errors are 539...
Is it make any problem?.. if i want fix the problem what i need to do?
Transmit                                Receive
945130476 Bytes                        704286385 Bytes
  4627987 Frames                         2896862 Frames
   493692 Multicast frames                     0 FCS errors
   310672 Broadcast frames                 24905 Multicast frames
        0 Pause frames                      5318 Broadcast frames
        0 Total collisions                   539 False carrier errors
  1496870 Minimum size frames
  2061206 65 to 127 byte frames
   813245 128 to 255 byte frames
   225429 256 to 511 byte frames
   261930 512 to 1023 byte frames
  2711638 1024 to 1518 byte frames
Thanks & Regards,
Srinivas.
1)  Is there a problem from a end user perspective?
2) Can you move it to a diff port to see if problem stays on port or cable
3)  If problem follows cable, on  the remote device can you move port to see if problem stays with port or cable.
4) I believe problem will be with cable, if so, new cabling (or ends).
Dude,
Let's settle this once and for all.
How important is this client connected to this port?  If it's that important, GET A TDR TEST DONE!
For the OP:
How to use Time-Domain Reflectometer (TDR)
https://supportforums.cisco.com/docs/DOC-18983
Post results.
