NTP Synchronization problem 2600 router
johnramz
Level 3
Level 3
Cisco COmmunity:
In the below setup the CISCO 2600 router is not synchronizing with external NTP server
PLease help
John
Setup:
INTERNET ISP router ======CISCO ASA5505(10.1.1.2)======fa0/1CISCO 2600fa0/0=====Users
The goal is to synchronize the 2600 with an External NTP server. The ASA is already synchronized after using just these commands:
clock timezone UTC -6
ntp server 38.106.177.10
ON THE 2600 router I get these outputs after 3 hours:
RTR#sh ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18
reference time is 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
RTR#sh ntp association
      address         ref clock     st  when  poll reach  delay  offset    disp
~38.106.177.10    0.0.0.0          16     -    64    0     0.0    0.00  16000.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
RTR# debug ntp packet
*Apr  3 18:28:01.065: NTP: xmit packet to 38.106.177.10:
*Apr  3 18:28:01.065:  leap 3, mode 3, version 3, stratum 0, ppoll 64
*Apr  3 18:28:01.065:  rtdel 0000 (0.000), rtdsp 10001 (1000.015), refid 00000000 (0.0.0.0)
*Apr  3 18:28:01.065:  ref 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  org 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  rec 00000000.00000000 (18:00:00.000 CST Thu Dec 31 1899)
*Apr  3 18:28:01.065:  xmt AF68AA11.10C7B7FB (18:28:01.065 CST Sat Apr 3 1993)
Configuration
RTR#sh run
Building configuration...
Current configuration : 1853 bytes
version 12.2
service timestamps debug datetime msec localtime
service password-encryption
hostname RTR
clock timezone CST -6
clock summer-time CDT recurring
ip subnet-zero
ip domain-name domain.com
ip name-server 10.250.100.1
interface FastEthernet0/0
ip address 10.250.1.113 255.255.0.0
no ip proxy-arp
ip route-cache flow
speed auto
full-duplex
interface FastEthernet0/1
ip address 10.1.1.1 255.255.0.0
duplex auto
speed auto
ip flow-export destination 10.250.100.60 2055
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip route 10.210.0.0 255.255.0.0 10.250.1.111
ip route 10.220.2.0 255.255.255.0 10.250.1.111
ip route 10.230.0.0 255.255.0.0 10.250.1.111
ip route 10.231.0.0 255.255.0.0 10.250.1.111
ip route 10.240.0.0 255.255.0.0 10.250.1.111
ip route 10.241.0.0 255.255.0.0 10.250.1.111
ip route 10.242.0.0 255.255.0.0 10.250.1.111
ip route 172.16.0.0 255.255.0.0 10.250.1.112
ip route 172.30.1.0 255.255.255.0 10.1.1.2
ip route 192.168.3.0 255.255.255.0 10.250.1.111
ip route 192.168.4.0 255.255.255.0 10.250.1.111
ip route 192.168.100.0 255.255.255.0 10.250.1.111
ip http server
line con 0
line aux 0
line vty 0 4
password xxxxxxx
login
ntp source FastEthernet0/1
end
22 Replies 22
John Blakley
Is this router in front of your ASA or behind your ASA? You may have to set the clock manually on the 2600 a little closer to the real time. If NTP is way off, the synchronization may not happen at all.
HTH,
John
HTH, John *** Please rate all useful posts ***
The router is behind the ASA. I tried to show that in the text diagram in my question.
Ah...
Do you have an acl on your inside interface on the ASA? If so, you'll need to allow udp 123 through for ntp traffic.
I completely missed the diagram
HTH,
John
No ACLs on inside interface. Why would the ASA itself communicates with external NTP without being explicitely allowed.? I assume because traffic coming from behind Inside to Outside is allowed.
John
That's correct. The ASA can communicate with the NTP server because it's locally generated traffic. The router on the other hand has to go through the ASA to get to it. If you don't have any acls on the inside interface, the traffic originating from the inside is automatically allowed out. Can you post your config for the ASA by chance?
j.blakley thanks for your reply. Here is is the ASA config:
ASA Version 8.2(1)
hostname ASAdct5505
domain-name default.domain.invalid
names
interface Vlan1
nameif inside
security-level 100
allow-ssc-mgmt
ip address 10.1.1.2 255.255.0.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.X 255.255.255.240
interface Vlan3
description DMZ
nameif DMZ
security-level 50
ip address 172.30.1.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner login Only for authorized users . PLease disconnect if you are not one.
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group network obj_172.22.7.0
network-object 172.22.7.0 255.255.255.0
access-list from_outside extended permit tcp any host 12.156.156.211 eq 3389
access-list from_outside extended permit tcp any host 12.156.156.212 eq 3389
access-list DMZ_in extended permit ip 172.30.1.0 255.255.255.0 10.0.0.0 255.0.0.
access-list DMZ_in extended permit tcp 172.30.1.0 255.255.255.0 any eq www
access-list DMZ_in extended permit tcp 172.30.1.0 255.255.255.0 any eq https
access-list DMZ_in extended permit udp 172.30.1.0 255.255.255.0 any eq domain
pager lines 24
logging enable
logging buffer-size 1000000
logging monitor debugging
logging buffered debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu DMZ 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (DMZ) 1 172.30.1.2-172.30.1.200
nat (inside) 1 10.250.0.0 255.255.0.0
nat (outside) 1 10.250.2.0 255.255.255.0
nat (DMZ) 1 172.30.0.0 255.255.0.0
static (inside,DMZ) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
access-group from_outside in interface outside
access-group DMZ_in in interface DMZ
route outside 0.0.0.0 0.0.0.0 X.X.X.X 1
route inside 10.0.0.0 255.0.0.0 10.1.1.1 1
route inside 172.16.0.0 255.255.0.0 10.1.1.1 1
route inside 192.168.0.0 255.255.0.0 10.1.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 10.250.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto ipsec transform-set 3DES-SHA-HMAC esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
tftp-server inside 10.250.1.10 /asacurrentconfig.txt
webvpn
svc image disk0:/anyconnect-win-2.5.3055-k9.pkg 1
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
service-policy global_policy global
prompt hostname context
: end
smehrnia
Level 11
Level 11
can you successful ping the NTP server from ur router?
Soroush.
Hope it Helps!
Soroush.
I can ping the NTP server from ASA but not from 2600 router. I cannot see how the ASA could be blocking NTP traffic if the ASA itself communicates with the same NTP server just fine
john
the traffic which is originated from the device itself, and the traffic passing through the device are two different stories.
if it thats just the NTP traffic that you have the difficulty passing through ASA make an exception and let it pass, the Source and Destination (for both ways RX/TX) is known, specific config.
plz Rate if it helped,
Soroush.
Hope it Helps!
Soroush.
Leo Laohoo
Have you tried other NTP servers?
Look for your local NTP server from the link Stratum Two Time Servers.
Yes I have
from this Page
Sorry, I didn't make myself clear here ... Can you ADD more NTP server addresses to your config and try so the appliance can do a round-robin?
Have you tried setting up captures on your ASA to see if its getting to the inside interface on the ASA. You can then setup a capture inbound on the outside interface to see if its responding. If the NTP server is not responding then that's not on you. I would try to verify traffic from Traffic Initiator to Traffic Destination and back to Traffic Initiator.
pjmonline
Level 3
Level 3
On my router 2901 my command is
ntp server 10.1.1.7 prefer
I don't have anything about ntp source fa 0/1. One other option is get time from the Asa.
