CRC errors on fibre port between 6509 and 3750
markc.williams
Hi all.
I'm having an issue all our 3750's (45 in total) connected to our 6509's (CatOS).
The 3750's are connected to the 6509s via fibre. on G1/0/1 and G1/0/4, using flexlink, G1/0/1 is that active link
On every switch, G1/0/1 shows input/CRC errors.... the 6509 doesnt show any output errors
It increments by one every 30 seconds.
from 3750:
5 minute output rate 2000 bits/sec, 2 packets/sec
125097 packets input, 40908607 bytes, 0 no buffer
Received 121817 broadcasts (0 multicast)
113 input errors, 113 CRC, 0 frame, 0 overrun, 0 ignored
from the 6509:
(enable) sh port counters 7/13
Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
7/13 0 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
7/13 0 0 0 0 0 0 -
Port Last-Time-Cleared
config on 3750:
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 1,10,555,600
switchport mode trunk
switchport nonegotiate
switchport backup interface Gi1/0/4
udld port aggressive
I've test new fibre, new SFP and Gbics.
Disable CDP.. but still getting errors
any help would be appreciated
lamav
Level 8
Level 8
Mark:
What are your speed and duplex settings on both ends?
Do you auto-negotiate or hard code?
Are you consistent?
Carl Andress
Mark, just curious if you found a solution to this. I have also seen this behavior, I'm not sure what's causing it.
u can check same fiber on other port and then check if u recieving crc. if this is confirmed.
Jawad
Jawad
You are responding to a 5 years old thread. People has move on since then.
