CRC's question
hernanseijas
Visitor
Is there a way to put in the router log the date and time when a CRC appears in an interface?
for example:
I cleared the counters and one day after I see that there are 10 CRC's in the interface.
How can I know at what time the CRC appeared?
Regards and thanks
spremkumar
Level 11
Level 11
hi
AFAIK you wont be able to ascertain the time during when the CRC's appeared on the interface.
Instead you can try finding out the reason and start enforcing procedure to avoid the same..
regds
bjornarsb
Level 9
Level 9
I believe that you get a HighErrorRate message, but you need to do a sh interface to see what type of errors you have.
BR,
Bjornarsb
