Create VLAN on Cisco 2948G switch running on CAT OS
ray_stone
Hello Experts,
I'm trying to configure VLAN on Cisco 2948G switch running on CAT OS and getting the following error:
VTP advertisements transmitting temporarily stopped,
and will resume after the command finishes.
Cannot add/modify VLANs on a VTP server without a domain name.
I'm using this command "set vlan 2 name corporate" that I believe is correct.
Please assist.
Thanks.
9 Replies 9
I configured my last CatOS switch probably 10 years ago, so I don't really remember if the followind should be ok. But the message sounds like that you should configure VTP correctly:
set vtp domain YOUR-VTP-DOMAIN mode server
   or
set vtp domain YOUR-VTP-DOMAIN mode transparent
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
ray_stone
I don't want to configure VTP, just create a simple VLAN, that's it..
if you don't want VTP, then configure it just with the correct mode for that which is transparent.
What is a correct mode as I'm not good on CAT OS. Please provide correct command, if possible
that should be:
Is it compulsory?
I don't have any more documentation on that device/CatOS. But your error-code sounds like if it would be needed to correct your config.
Ray,
CATOS commands:
Complete these steps:
  1. Issue this command in order to set the domain name:
    set vtp domain name
    Note: When you configure a new switch, the VTP domain name should be configured before you create any non-default VLANs.
  2. Issue this command in order to set the mode:
    set vtp mode [server | client | transparent]
  3. Issue these commands in order to monitor the VTP operation and status:
    show vtp domain
    show vtp statistics
Inayath
*Plz rate all usefull posts.
