Creating Ether-channel between Cisco 2960-X Switches
Hi All,
I am trying to configure Ether-Channel between my two 2960-X switches but i am failing at doing so. Could anyone help understand and configure it properly. Below is my setup and requirement.
SW01:
Gig 1/0/23 & Gig 1//0/24 are connected to Cisco ASA Firewall and are configured as etherchannel.
interface Port-channel1
 switchport mode trunk
interface GigabitEthernet 1/0/23
 swtichport mode trunk
 channel-group 1 mode on
interface GigabitEthernet 1/0/24
There are VLANs (10,20,30,40) configured on SW01 too as i have multiple sub-interfaces on Cisco ASA.
I have a new SW02 where i am connecting more devices so i pulled two cables from SW01 to SW02 and did the below configuration.
SW01:
interface Port-channel2
interface GigabitEthernet 1/0/21
 channel-group 2 mode on
interface GigabitEthernet 1/0/22
SW02:
However i created VLANs 10,20,30,40 but i have no communication between them.
Kindly suggest.
@Mohammed
11 Replies 11
Mark Malone
Is the etherchannel up ? can you post show etherchannel summ
Hi Mark,
Below is the appropriate output;
SW01#sh etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Gi1/0/23(P) Gi1/0/24(P)
2      Po2(SD)          -        Gi1/0/6(D)  Gi1/0/8(D)
Port 23 & 24 = ASA
Port 6 & 8 = SW02
SW02#sh etherchannel summary
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
2      Po2(SD)          -        Gi1/0/1(D)  Gi1/0/2(D)
Hi the port-channel between the 2 2960s is po2 correct? No port-channel to the ASA on switch 2 yes as only 1 showing setup po2 ,po2 it's currently switched down state can you post the current config of there member ports 6,8,1 & 2, , is that the way you have it cabled those 4 ports connected directly between switches
Hi Mark,
Yes the port-channel between the switches is po2.
No port-channel to the ASA on SW2 its only on SW01 (po1).
SW01:
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
SW02:
interface GigabitEthernet1/0/1
Yes cables are connected between SW01 P6&P8 - SW02 P1&P2
@Mohammed
I see the PO to be down:-
2      Po2(SD)          -        Gi1/0/1(D)  Gi1/0/2(D)  >> donw sate.
So could we try the following:-
1- Remove the port-channel config from the ports and see if the links are coming back online?
2- Then once you confirmed that then shut down the ports at both the ends.
3- Configure the port-channel configuration and then applied the PO channel command for the physical interface.
4- Bring the physical interface both the ends.
5- Try not using the on mode.
Inayath
Regardless to what you mentioned above i did "shut & no shut" on both the interfaces and got the below error;
Aug  5 08:14:27.037: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi1/0/8, putting Gi1/0/8 in err-disable state
Aug  5 08:14:27.075: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Gi1/0/6, putting Gi1/0/6 in err-disable state
Could you also clarify on the above your points as i didn't understood.
@Mohammed
Are you using the range command to do this? bringing up 1 interface at a time can cause stp issues
Have you changed it to lacp or pagp instead of on mode
did you allow the switch to create to create the port-channel interface? do not create it yourself it automatically creates when you use the channel-group command
remove the config completely port-channel and default the interfaces then apply this
interface range g1/0/1 - 2
switchport nonegotiate
channel-group 2 mode desirable
shutdown
interface range g1/0/6 - 7
channel-group 2 mode active
shutdown
Then when the po is created each side and everything is configured bring them up together
no shut
no shut
Any luck doing it by range command ?
Hi Mark,
i did not do any other fresh config but just by doing "shut and no shut" on interface port-channel2 all started working fine.
Thanks for your inputs and great efforts.
@Mohammed
No problem glad you got it sorted
Ye i agree with InayathUlla below i would shut it down reapply it and use LACP , sometimes using on mode if not brought up correctly can cause issues like stp problems
For LACP thats all you need to change passive 1 side active on the other , keep the passive side shut down until your ready
channel-group 2 mode passive
