creating layer 3 SVI
penevsquare
Community Member
HI guys, I have an issue with my cisco 851W router
when I try to configure fast ethernet port , I keep getting an error:
IP addresses may not be configured on L2 links
according information from the forum I have to :
conf t
int <interface name/no>
no switchport mode
ip address x.x.x.x x.x.x.x
it`s still getting the error
or if you want the port to be a member of VLAN, do this-->
conf t
int vlan <no>
switchport access vlan <vlan name/no>
for instance if the internet comes via cable from 192.168.66.101 255.255.255.0
I have to configure
conf t
int vlan 1
ip address 192.168.66.101 255.255.255.0
int fastethernet 0
switchport access vlan 1
is this correct?
thanks in advance for your help
best regards
mahmoodmm
Community Member
Just create create the SVI and connect the connection on any port as by default all the ports are in vlan 1.
thank you very much indeed for your fast reply
the configuration should be:
R1#conf t
R1(config)#int vlan 1
R1(config-if)#ip address 192.168.66.101 255.255.255.0
R1(config)#interface fastEthernet 0
R1(config-if)#switchport mode access
R1(config-if)#switchport access vlan 1
R1(config-if)#no shut
thanks in advance
best regards
Hi.
Yes this should be enough.
