Creating Port-Channel using Web Interface
Bobby P
Level 3
Level 3
I'm not much on using the CLI.  My question is if I use the Web access page for our Cisco 9300 catalyst switch to create a port-channel what is the default protocol?  Is it LACP or PAgP.  These port-channels will be used for connecting to Meraki switches which only use LACP.
2 Accepted Solutions
Jaderson Pessoa
Dear boby,
The default settings are LACP, but you can choice for PAgP without problem.
Jaderson Pessoa
*** Rate All Helpful Responses ***
balaji.bandi
LACP is default, But when you configuring Meraki connecting to Live Environment bear in mind Spanning tree loops. ( make sure Meraki configured offline with different prioroty before connecting to Cat 9300)
https://documentation.meraki.com/zGeneral_Administration/Tools_and_Troubleshooting/Link_Aggregation_and_Load_Balancing#Configuring_Link_Aggregation_between_MS_and_Cisco_Switches
BB
Jaderson Pessoa
Dear boby,
Jaderson Pessoa
Thanks for the information.
balaji.bandi
BB
Thanks for the feedback.
