CSMA/CD
carl_townshend
Is this just how an ethernet network switch works ? whereas a hub is not this ?
carl
hitesharora
Community Member
Hi Carl,
Its the otherway round. Its how the hub works, switch is different.
Rgds
so what does what here then ? I thought a switch does this
bjw
Level 8
Level 8
CSMA/CD - Carrier Sense Multiple Access/Collision Detect.
10Base2 and 10Base5 - typically 10 MB/Half duplex. This is where there is a common tx/rx medium that all connected devices share. Collisions are normal, hosts listen and wait for open time to broadcast/send packets over the wire. This is what a legacy HUB does.
A Switched network allows each connected host/device to have a dedicated slice of the ethernet pie and collisions should theoretically never occur in FULL DUPLEX operation. However a switch port/interface configured as half duplex will electricaly function like it is a CSMA/CD Hub port and will normally accumulate collision errors, but ONLY on that port/interface, all other switch ports/interfaces running full duplex will never see these errors/conditions.
I have just been told by a ccie that csma/cd works on all ethernet networks no matter if its plugged into a hub or switch ? is this true ? can anyone explain in simple terms what it does ?
cheers
Carl
