11-28-2006 02:57 AM - edited 03-05-2019 01:03 PM
The documents related to CVDM doesn't mentionned that CVDM is supported for the Supervisor Engine 32.
Does anyone know if it's still supported ?
I have Cat6509E with 2 x Sup32 and IOS 12.2.18SXF6
11-28-2006 03:04 AM
Hi Friend,
Sup32 is not supported by CVDM.
There are currently no plans to support this supervisor card.
Only the Sup1, 2 and 720 support the embedded
CVDM in any version.
Ankur
*Pls rate all helpfull post
11-28-2006 03:04 AM
Hi Jean,
CVDM is not supported on Sup32 and there are no plans for a release of CVDM to support the Sup32.
HTH,Please rate if it does.
-amit singh
