DAI conflict with inter-VLAN routing
raoufesi
Hey community,
I have a 3-tier architecture, with 4 VLANs 10-40, I configured inter-VLAN routing on distribution switches and it's working fine, however when I pursued to configure DAI on access and distribution switches inter-VLAN routing is not working anymore, I configured the interfaces connected to switches as trusted and left those connected to end hosts on their untrusted default state, can someone help me with this issue ?
Keep in mind the ARP inspection is based off the DHCP Snooping table. While you have DHCP snooping enabled are the hosts being assigned IP addresses from a DHCP and is the DHCP snooping table on ACC_SW1 being populated from that information? Can you show the output of the command: show ip dhcp snooping binding
Also if you can please provide the output of the command: debug arp snooping after a failed ping test. If you get output like the below then it didnt find a valid entry in the DHCP snooping table.
May 15 02:28:20.122: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Res) on Gi0/0, vlan 10.([5254.000e.520d/172.16.10.1/5254.0004.02f2/172.16.10.13/02:28:20 UTC Wed May 15 2024])
-David
19 Replies 19
balaji.bandi
you need to provide more information about environment and their connectivity.
what model device ?
what IOS code running ?
how these switches connected each other ?
where did you applied DAI config ?
before DAI applied everything working between 10-40 VLAN ?
share the configuration and output as much as you can here to understand the setup.
just for reference  :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25ew/configuration/guide/conf/dynarp.html
BB
Dynamic ARP Inspection
I applied both DHCP snooping and DAI as follows (for access switches):
ip dhcp snooping vlan 10,20,30,40
ip arp inspection vlan 10,20,30,40
when configuring DHCP snooping only inter-vlan routing works fine, once issuing the "ip arp inspection vlan 10,20,30,40" command it fails...
MHM
MHM
Yes, I even deleted the DAI configuration from DIST switches and only
focused on ACC switches... also I configured The ports connected to other
switches (AKA DIST switches in this case) as trusted
MHM
I tried different values... ranging from 50 to 500
post the full running configs (sh run) of all devices involved, as well as a schematic drawing of your topology, showing how your devices are physically and logically connected...
MHM
MHM
raoufesi
Here is the topology... I am running a PNETLab environment, and all of the switches are L3 switches of which the Cisco IOS version is 15.2
I configured DAI and DHCP snooping on access switches only, here are the running-config of the access and distribution (since it is the same conf for all switches so I just posted 1 access and 1 distribution)
ACCESS_SW1 :
Current configuration : 3549 bytes
! Last configuration change at 21:46:38 UTC Tue May 14 2024
version 15.2
service compress-config
hostname ACC_SW1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip dhcp snooping information option
ip dhcp snooping
no ip domain-lookup
ip cef
no ipv6 cef
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause arp-inspection
errdisable recovery interval 600
spanning-tree mode rapid-pvst
interface Ethernet0/0
switchport access vlan 10
switchport mode access
switchport port-security
spanning-tree portfast edge
spanning-tree bpduguard enable
ip dhcp snooping limit rate 100
interface Ethernet0/1
switchport access vlan 20
interface Ethernet0/2
switchport access vlan 30
spanning-tree guard root
interface Ethernet0/3
switchport trunk allowed vlan 10,20,30,40
switchport trunk native vlan 99
switchport mode trunk
ip arp inspection trust
ip dhcp snooping trust
interface Ethernet1/0
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
ip forward-protocol nd
ip tcp synwait-time 5
ip http server
ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
DIST_SW1 :
version 15.2
hostname DIST_SW1
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree vlan 10,20 priority 24576
spanning-tree vlan 30,40 priority 28672
interface Port-channel10
channel-group 10 mode active
interface Ethernet2/0
no switchport
ip address 10.1.1.98 255.255.255.252
interface Ethernet2/1
no switchport
ip address 10.1.1.109 255.255.255.252
interface Ethernet2/2
interface Ethernet2/3
interface Ethernet3/0
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet3/3
interface Ethernet4/0
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet4/3
interface Ethernet5/0
interface Ethernet5/1
interface Ethernet5/2
interface Ethernet5/3
interface Ethernet6/0
interface Ethernet6/1
interface Ethernet6/2
interface Ethernet6/3
interface Ethernet7/0
interface Ethernet7/1
interface Ethernet7/2
interface Ethernet7/3
interface Ethernet8/0
interface Ethernet8/1
interface Ethernet8/2
interface Ethernet8/3
interface Ethernet9/0
interface Ethernet9/1
interface Ethernet9/2
interface Ethernet9/3
interface Ethernet10/0
interface Ethernet10/1
interface Ethernet10/2
interface Ethernet10/3
interface Ethernet11/0
interface Ethernet11/1
interface Ethernet11/2
interface Ethernet11/3
interface Ethernet12/0
interface Ethernet12/1
interface Ethernet12/2
interface Ethernet12/3
interface Ethernet13/0
interface Ethernet13/1
interface Ethernet13/2
interface Ethernet13/3
interface Ethernet14/0
interface Ethernet14/1
interface Ethernet14/2
interface Ethernet14/3
interface Ethernet15/0
interface Ethernet15/1
interface Ethernet15/2
interface Ethernet15/3
interface Vlan10
ip address 10.1.1.1 255.255.255.224
interface Vlan20
ip address 10.1.1.65 255.255.255.240
interface Vlan30
ip address 10.1.1.81 255.255.255.240
interface Vlan40
ip address 10.1.1.33 255.255.255.224
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
-David
It worked !
It turned out that DHCP was not configured yet, end hosts were not able to get IP addresses dynamically, after configuring DHCP on the server I re-issued the "ip arp inspection vlan 10,20,30,40" and "ip dhcp snooping vlan 10,20,30,40" commands and everything worked great !
Thank y'all for helping, best community ever ♥
