Dark Fiber, Cisco 1000BASE-LX/LH SFP, 6509, 3750
Ton V Engelen
Level 3
Level 3
I have very little experience with optical gbics and i am wondering if i can connect a remote location (10 miles away ) with Cisco 1000BASE-LX/LH SFP gbics over dark fiber without a cwdm solution.
I want to build this link from a 6509 to a 3750 switch. From what i ve read it should be possible, but i am wondering if both the 3750 and 6509 switches are supporting this.
Thanks in advance!!
2 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, you shouldn't need a CWDM (or DWDM) SPF unless you need more than 1 gig across the same fiber.
The distance, though, for a LX/LH is greater than spec.  The Cisco spec for those SPFs is 10 Km (see Table 1 in
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html).
The EX SPF should do the distance, but unsure you'll find one supported for both the 3750 and 6509.  (NB: use
5-dB attenuator for back-to-back.)  See http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
If not, the ZX SPF will work although for 10 miles you may need an attenuator .
"The minimum link distance for ZX GBICs is 6.2  miles (10 km) with an 8-dB attenuator installed at each end of the link.  Without attenuators, the minimum link distance is 24.9 miles (40 km)."
and
"When shorter lengths of single-mode fiber are used, it may be necessary  to insert an inline optical attenuator in the link to avoid overloading  the receiver. Use the following guidelines:
Insert  a 10-dB inline optical attenuator between the fiber-optic cable plant  and the receiving port on the 1000BASE-ZX module at each end of the link  whenever the fiber-optic cable span is less than 15.5 miles (25 km).
Insert  a 5-dB inline optical attenuator between the fiber-optic cable plant  and the receiving port on the 1000BASE-ZX module at each end of the link  whenever the fiber-optic cable span is equal to or greater than 15.5  miles (25 km) but less than 31 miles (50 km). "
The 3750/3750G/3750E/3750X will support GLC-LH.
Table 6 Catalyst 3700 Series Switches Support
5 Replies 5
Joseph W. Doherty
Disclaimer
Posting
and
Hi, Joseph, thanks a lot for you reply.
The distance is going to be 7,2 kilometers, i just heard.
So the LX/LH could do the trick then i guess. (I dont need more than 1 gig)
But i ve read that only the 3750-E are supported in the 3750 series for these Gbic;s, which could mean the 3750 is not?
Joseph, Leo, thanks much.
Thanks for the ratings.
