cisco 3400 not routing
cboyd2011
Hello All,
I have a cisco 3400 connected to a Cisco 831
The 831 is online and working fine, also the computers connected to it work fine as well
I connected a Cisco 3400 up to it on fa0/24
the light comes the 831 and 3400 just fine
The 3400 and 831 show each other in the ARP tables but they will not ping each other nor will the 3400 get out the the internet
I included my config file and some commands I ran
Any Ideas?
Thank You very much for ready and any help you can provide
Cisco IOS Software, ME340x Software (ME340x-METROACCESS-M), Version 12.2(25)SEG1
, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 07-Aug-06 19:02 by myl
Image text-base: 0x00003000, data-base: 0x00C0489C
ROM: Bootstrap program is ME340x boot loader
BOOTLDR: ME340x Boot Loader (me340x-HBOOT-M) Version 12.2(25r)EX, RELEASE SOFTWA
RE (fc4)
test uptime is 6 hours, 10 minutes
System image file is "flash:me340x-metroaccess-mz.122-25.SEG1/me340x-metroaccess
-mz.122-25.SEG1.bin"
cisco ME-3400-24TS-A (PowerPC405) processor (revision C0) with 118784K/12280K by
tes of memory.
config:
Current configuration : 1684 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname test
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
vlan 250
name MGT
interface FastEthernet0/1
shutdown
interface FastEthernet0/2
shutdown
interface FastEthernet0/3
shutdown
interface FastEthernet0/4
shutdown
interface FastEthernet0/5
shutdown
interface FastEthernet0/6
shutdown
interface FastEthernet0/7
shutdown
interface FastEthernet0/8
shutdown
interface FastEthernet0/9
shutdown
interface FastEthernet0/10
shutdown
interface FastEthernet0/11
shutdown
interface FastEthernet0/12
shutdown
interface FastEthernet0/13
shutdown
interface FastEthernet0/14
shutdown
interface FastEthernet0/15
shutdown
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
speed 100
duplex full
interface GigabitEthernet0/1
port-type nni
interface GigabitEthernet0/2
port-type nni
interface Vlan1
ip address dhcp
no ip route-cache
ip default-gateway 192.168.4.1
no ip http server
line con 0
line vty 0 4
password TEST
no login
length 0
line vty 5 15
password TEST
no login
length 0
end
test#sh int vlan1
Vlan1 is up, line protocol is up
  Hardware is EtherSVI, address is 001c.b18f.cac0 (bia 001c.b18f.cac0)
  Internet address is 192.168.4.22/24  <<<<<<<<<<<<<<-------------------------------------------
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 00:17:25, output 00:34:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     596 packets input, 56255 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicast)
     91 packets output, 9931 bytes, 0 underruns
     0 output errors, 0 interface resets
test#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  127.0.0.20              -   001c.b18f.ca80  SNAP   Virtual1
Internet  192.168.4.1            37   0011.216f.af11  ARPA   Vlan1
Internet  192.168.4.22            -   001c.b18f.cac0  ARPA   Vlan1
test#ping 4.2.2.1
Sending 5, 100-byte ICMP Echos to 4.2.2.1, timeout is 2 seconds:
06:15:29: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending
06:15:29: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending full p
acket.
06:15:31: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending
06:15:31: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending full p
acket.
06:15:33: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending
06:15:33: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending full p
acket.
06:15:35: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending
06:15:35: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending full p
acket.
06:15:37: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending
06:15:37: IP: s=192.168.4.22 (local), d=4.2.2.1 (Vlan1), len 100, sending full p
acket.
Success rate is 0 percent (0/5)
majed.balsharaf
Hi Christopher
   3400 switch is a Metro Ethernet switch.and by default all the ports are in uni mode,except 2 uplinks which are in nni. Uni means user network interface and it is isolated. nni is network node interface. NNI is used to connected to routers or another switch.
we can make 4 ports as nni.
by default on every cisco switch all the ports are in nni. but metro Switches like 34xx and 24xx are uni ports.
41 Replies 41
jimmysands73_2
Level 5
Level 5
What the statsus of int FastEthernet0/24?  Are the ports in the same VLANs?  Post the config of the other side also. I believe routing is not the issue becase you have to directly connected devices.
Thanks for your post
Here is the status of the fa0/24
test#sh int fa0/24
FastEthernet0/24 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 001c.b18f.ca9a (bia 001c.b18f.ca9a)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:08, output hang never
     5225 packets input, 811710 bytes, 0 no buffer
     Received 4714 broadcasts (0 multicast)
     0 watchdog, 2914 multicast, 0 pause input
     7907 packets output, 510983 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Yes all ports are on vlan1 or they should be because that is the default vlan on all interfaces
Cisco 831 config:
Internet831#sh run
Building configuration...
Current configuration : 9645 bytes
! Last configuration change at 11:24:18 EDT Wed Jun 1 2011
! NVRAM config last updated at 11:24:29 EDT Wed Jun 1 2011
version 12.4
no service pad
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Internet831
boot-start-marker
boot system flash c831-k9o3sy6-mz.124-13a.bin
boot-end-marker
memory-size iomem 5
logging buffered 14096 debugging
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring 1 Sun Apr 0:00 last Sat Oct 0:00
no ip dhcp use vrf connected
ip dhcp pool 0
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
   dns-server 4.2.2.1
ip cef
interface Ethernet0
description LAN
ip address 192.168.4.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1
description WAN
ip address dhcp
ip nat outside
duplex auto
interface Ethernet2
description NOT USED
no ip address
ip nat inside
shutdown
interface FastEthernet1
description Web/FTP Server/DNS
duplex auto
speed auto
interface FastEthernet2
description Exchange/DNS/TFTP/TACACS
duplex auto
speed auto
interface FastEthernet3
description Linux Server
duplex auto
speed auto
interface FastEthernet4
description Wireless/Multimedia/Cisco Lab
duplex auto
speed auto
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Ethernet1 overload
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 23 permit 192.168.4.0 0.0.0.255
access-list 23 permit 192.168.5.0 0.0.0.255
tftp-server flash:c831-k9o3sy6-mz.124-2.T4.bin
control-plane
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 30 0
logging synchronous
login
scheduler max-task-time 5000
ntp clock-period 17180175
ntp server 128.138.140.44
end
Boyds_Internet831#sh arp
Internet  192.168.4.50            0   Incomplete      ARPA
Internet  192.168.0.13            -   0011.216f.af12  ARPA   Ethernet1
Internet  192.168.0.1             0   0009.0f59.2236  ARPA   Ethernet1
Internet  192.168.4.1             -   0011.216f.af11  ARPA   Ethernet0
Internet  192.168.4.2             0   0018.8b66.75b8  ARPA   Ethernet0
Internet  192.168.4.22           19   001c.b18f.cac0  ARPA   Ethernet0
I don't think it's anything to do with the Cisco 831 because I connected the Cisco 3400 to my Peplink load balenace router and it did the exact same thing.
on the 3400 can you do a debug arp while pinging 4.2.2.1 and on 831 can you do a sh ip int eth0 and a sh ip nat trans at the same time
Also on 831 do a sh ip route.
Post all these here.
Regards.
Alain.
Here is the information you requested
Hope it helps!
test#ping 4.2.2.1
Internet831#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C    192.168.4.0/24 is directly connected, Ethernet0
     192.168.0.0/26 is subnetted, 1 subnets
C       192.168.0.0 is directly connected, Ethernet1
S*   0.0.0.0/0 [254/0] via 192.168.0.1
Internet831#sh ip int eth0
Ethernet0 is up, line protocol is up
  Internet address is 192.168.4.1/24
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain inside
  BGP Policy Mapping is disabled
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
Internet831#sh ip nat trans
Pro Inside global         Inside local          Outside local         Outside global
icmp 192.168.0.13:17      192.168.4.22:17       4.2.2.1:17            4.2.2.1:17
udp 192.168.0.13:123      192.168.4.50:123      128.138.140.44:123    128.138.140.44:123
ok,
Can you do this on 831:
1) create extended acl permitting pings from any to any
    access-list XXX permit icmp any any
2) direct debug output to buffer
   no logging console debug
  logging buffered 10000
logging buffered debug
3) apply this ACL to a debug
debug ip packet detail XXX
4) run your ping from 192.168.4.2 to 4.2.2.1
5) show log to view the debug output and copy-paste then send here.
Regards.
Alain.
I added into ACL for cisco 831:
access-list 100 permit icmp any any
then ran command:
Ineternet831#debug ip packet detail 100
IP packet debugging is on (detailed) for access list 100
If I ping from the 3400 to the 831 (pinged 192.168.4.1) nothing was logged
If I ping from the 831 to the 3400 (pinged 192.168.4.22) logged the following:
12w0d: IP: tableid=0, s=192.168.4.1 (local), d=192.168.4.22 (Ethernet0), routed via FIB
12w0d: IP: s=192.168.4.1 (local), d=192.168.4.22 (Ethernet0), len 100, sending
12w0d:     ICMP type=8, code=0
That's really weird because we should see the echo-replies and I wonder why the echo-requests aren't seen on the router as you have no ACL denying pings.But that is not the important thing what I wanted to see is if there was a response back from 4.2.2.1  and so the test was pinging 4.2.2.1 while doing the debug but as always I forgot that debug packets are process switched packets and so you'll have to disable cef temporarily to see these debugs.
So let's try it another way: Can you do a traceroute to 4.2.2.1 on 3400.
Regards.
Alain.
test#traceroute 4.2.2.1
Tracing the route to
1  *  *  *
  2  *
23:03:41: IP ARP: rcvd req src 192.168.4.1 0011.216f.af11, dst 192.168.4.50 Vlan
1 *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *1  *  *  *
  2  *
1 *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
times out to 30
ok,
so it seems the 831 can't get to 4.2.2.1, can you do a ping from 831 to 4.2.2.1
Regards.
Alain.
4.2.2.1 is just a L3 DNS server
the 831 works fine and I'm online with my PC behind it now
Yes I can ping from the 831 to 4.2.2.1
Internet#ping 4.2.2.1
Sending 5, 100-byte ICMP Echos to 4.2.2.1, timeout in 2 secounds:
Seccess rate is 100 percent (5/5), round-trip min/avg/max = 20/20/20 ms
I know 4.2.2.1 is a dns server but i must admit i'm at loss here wheter it is because i'm very tired or because i'm missing something very obvious i don't know but for me this weird.
let's summarize:
-your 3400 can ping the 831 internal address
-your 831 can ping 4.2.2.1
-your nat is working properly on 831 as we observed
-But you can't ping 4.2.2.1 from 3400 and traceroute miserably fails at first hop which is 831 router
-did we try pinging from 3400 to outside interface of 831 router? did it work? it should
Let's try some more debug if it possible:
while pinging to 4.2.2.1 from 3400( 192.168.4.22) disable cef with global config command no ip cef then redo the debug ip packet detail XXX where XXX is the ACL permitting icmp any any
do also a debug ip nat  XXX
Regards.
Alain.
I do thank you for your help
I just wanted to make sure you knew what the 4.2.2.1 is
no it can not (-your 3400 can ping the 831 internal address)
yes it can (-your 831 can ping 4.2.2.1)
yes it is (-your nat is working properly on 831 as we observed)
correct (-But you can't ping 4.2.2.1 from 3400 and traceroute miserably fails at first hop which is 831 router)
yes we did and it didn't (-did we try pinging from 3400 to outside interface of 831 router? did it work? it should)
no ip cef is not a command
test(config)#no ip cef
% Invalid input detected at '^' marker.
test(config)#no ip ?
Global IP configuration subcommands:
  access-list           Named access-list
  accounting-list       Select hosts for which IP accounting information is kept
  accounting-threshold  Sets the maximum number of accounting entries
  accounting-transits   Sets the maximum number of transit entries
  address-pool          Specify default IP address pooling mechanism
  alias                 Alias an IP address to a TCP port
  arp                   IP Arp features
  default-gateway       Specify default gateway (if not routing IP)
  dhcp                  Configure DHCP server and relay parameters
  dhcp-client           Configure parameters for DHCP client operation
  dhcp-server           Specify address of DHCP server to use
  domain                IP DNS Resolver
  domain-list           Domain name to complete unqualified host names.
  domain-lookup         Enable IP Domain Name System hostname translation
  domain-name           Define the default domain name
  finger                finger server
  ftp                   FTP configuration commands
  gdp                   Router discovery mechanism
  gratuitous-arps       Generate gratuitous ARPs for PPP/SLIP peer addresses
  host                  Add an entry to the ip hostname table
  host-routing          Enable host-based routing (proxy ARP and redirect)
  hp-host               Enable the HP proxy probe service
  http                  HTTP server configuration
  icmp                  ICMP options
  igmp                  IGMP global configuration
  local                 Specify local options
  name-server           Specify address of name server to use
  radius                RADIUS configuration commands
  rcmd                  Rcmd commands
  reflexive-list        Reflexive access list
  security              Specify system wide security information
  source                IP source
  source-route          Process packets with source routing header options
  sticky-arp            Allow the creation of sticky ARP entries
  subnet-zero           Allow 'subnet zero' subnets
  tacacs                TACACS configuration commands
  tcp                   Global TCP parameters
  telnet                Specify telnet options
  tftp                  tftp configuration commands
ok,
so for cef you could try interface command( on the 831) : no ip route-cache cef on both ethernet interfaces.
But you're saying: we can't ping 831 interfaces and 4.2.2.1 but at the same time your nat translation is done( which is done after routing so we know nat and routing on the 831 is ok but it is also confirmed by the fact the 831 can ping 4.2.2.1.
But looking at all your previous tests we know the 3400 and the 831 each have the correct MAC in their arp cache  so L2 connectivity between the 2 should be good and at the same time when pinging from 3400 to 831 showed nothing in the debug but pings from 831 to 3400 showed the echo-requests going out without any problem but the ping was unsuccessful so there is a problem on the 3400 or the link between 3400 and 831
Can you do a sh mac address-table dynamic vlan 1 as  well as sh int f0/24 switchport
Regards.
Alain.
you are correct in your statements above
Here are the commands you requested:
test# sh mac address-table dynamic vlan 1
          Mac Address Table
Vlan    Mac Address       Type        Ports
   1    0011.216f.af11    DYNAMIC     Fa0/1
Total Mac Addresses for this criterion: 1
test#sh int f0/24 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: Off
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
I would update the IOS on the switch to see if that fixes it but it will not route anything
I have a cisco corp acct or whatever where I can download all the IOS's I want
