Datasheet WS-X45-SUP7L-E
mario-leitao
Level 2
Level 2
Anyone has more information on supervisor WS-X45-SUP7L-E?
I saw that it has 520Gbps of backplane, but does it supports Netflow? How many uplink does it has?
7 Replies 7
Edison Ortiz
This supervisor is not available as of today. Information I've gathered indicates that it supports (2) 10Gbps uplinks with SFP+ or (4) 1Gbps uplinks with regular SFP per Supervisor.
The fabric capacity is 540Gbps and supports NetFlow Lite.
Edison
Hi Edson thanks for the fast response,
I did a search on google and found some sites selling it (even CDW) and also saw this partnumber on the global pricelist.
Do you know when this supervisor will be available?
I believe by the end of this month. I don't have a concrete date.
Edison
For Sup7 or Sup7L, with LAN BASE license, does it require a seperate license to enable 10G uplink?
I recall Sup6/6L will need a 4K 10G uplink license.........
Jesus Sanchez
Level 2
Level 2
This is one of the few documents that i've found that reference to that Sup: http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/configuration/notes/OL_25750.html
There's still no official Datasheet (or at least i havent found it).
I can tell you that it should be orderable by now since you can configure it on a Cat4500 chassis at the Dynamic Config Tool. There's also a bundle that already includes that Sup (includes sup7L + two cards of 48 ports PoE+)
jobinluv1
Community Member
Here is a lot of data and specs on the Cisco WS-X45-SUP7L-E
Hope it helps!
