Dead interface???
jerry.sanderson
i have an interface on a 2950 cat switch that i cant get a single inteface (13) to turn up or light up
tried shut no shut and clear on the interface nothing worked any tips or is the int dead?
6 Replies 6
Hello Jerry,
try and reset the switch to factory defaults by pressing the Mode button for 10 seconds, which causes the switch ro reboot. When it boots, observe the LEDs, do they actually light up ?
You can also issue the exec command ´show post´ to check for any errors encountered during the self test. In this context, you might want to check the document below:
Catalyst 2950 Troubleshooting
http://www.cisco.com/en/US/partner/products/hw/switches/ps628/products_installation_guide_chapter09186a008007e87c.html
HTH,
GP
jerry.sanderson
yes they all light up
and when i issue the show post command it is passed
when i said a single interface i meant just one interface number 13
Hello Jerry,
what are you connecting to that port (13) ? I know that with e.g. some 10/100/1000 NICs, the switchport won´t come up unless you set it to fixed 100MB Full Duplex...
Check this document, it might apply to your specific situation:
Troubleshooting Cisco Catalyst Switches to NIC Compatibility Issues
http://www.cisco.com/warp/public/473/46.html#nic_comp
GP
100 mb nics have a total of 14 attached to the switch all of them the same and port 13 is the only one not working and double check the cables
Hello Jerry,
try and put the port in loopback state with the interface command ´loopback´ and see if it comes up.
Also, check for any errors with the command ´show ethernet-controllers interface FastEthernet0/13´...
GP
