Rate-Limit on 3750 Switch
alexb
Is the rate-limit command supported in IOS ver 12.1 on the 3750 switch? If so, is there a place in the Network Assistant to configure this or only available from the console?
Thanks in advance!
Prashanth Krishnappa
You can limit bandwidth on an egress interface. For ingress, consider applying a policer. The following page should help you with both
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12119ea1/3750scg/swqos.htm
