Default Route on Vlan2
imranraheel
i have to assign a seperate default route on vlan2. Please let me know how to do that I already have a default route on Vlan 1 but dont want to use that for vlan2
6 Replies 6
Jon Marshall
You can't but you can use PBR (Policy Based Routing) to send vlan 2 traffic to a different next-hop.
Jon
How to implement that in a 3550 switch can you help.
Firstly your 3550 needs to be running the EMI image. If it is running the SMI image it will not support PBR.
Assuming vlan 2 is 192.168.5.0 255.255.255.0
access-list 101 permit ip 192.168.5.0 255.255.255.0 any
route-map PBR permit 10
match ip address 101
set ip next-hop
int vlan 2
ip policy route-map PBR
The above config will send ALL traffic from vlan 2 to the next-hop IP address in the above config.
If you only want to send some traffic then you need to be more specific in your acl.
Jon
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(35)SE, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sun 03-Dec-06 14:34 by yenanh
Image text-base: 0x00003000, data-base: 0x00E85C24
ROM: Bootstrap program is C3550 boot loader
MIXIT_Switch1 uptime is 5 days, 1 hour, 59 minutes
System restarted at 13:50:32 Eastern Wed Jan 6 2010
System image file is "flash:c3550-ipservicesk9-mz.122-35.SE/c3550-ipservicesk9-m
z.122-35.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. WS-C3550-48 (PowerPC) processor (revision L0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0812X0WX
Last reset from warm-reset
Running Layer2/3 Switching Image
If
Cisco
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0F:8F:E9:63:80
Motherboard assembly number: 73-5701-09
Power supply part number: 34-0967-02
Motherboard serial number: CAT08120A28
Power supply serial number: LIT080602QF
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0812X0WX
Configuration register is 0x10F
Thats the version which I have.Can you let me know if PBR works in it
Yes this should support PBR.
Jon
Jon is correct in his answer. Here is a link which will run down the flexability you have with PBR.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfpbr_ps1835_TSD_Products_Configuration_Guide_Chapter.html
