Default routing problem in E-bgp
suhailpuri
We have two data centers one in america D1 and another in europe D2 , both data center wan links are connected to mpls
the wan router of each data center has a wan link with ebgp session towards mpls and another interface connecting to internet router , so if there is intranet traffic then it goes over mpls and internet traffic goes to internet router at each data center
both routers have default route pointing towards EBGP neighbor , the problem is that if the servers in europe need to access internet then the traffic instead of going through internet router in europe goes through mpls into america datacentre and then america internet router  and not utilizing the local internet router in europe
The IGP in both locations is EIGRP and EGP is EBGP
can some one help with this ?
    Giuseppe Larosa
    Hello Suhail,
    my guess is that the Europe based WAN router is receiving a default route on the MPLS WAN link.
    You can check the status of Europe WAN router with
    show ip route 0.0.0.0
    show ip bgp 0.0.0.0
    It is likely that you will find two eBGP advertisements for net 0.0.0.0/0 with the one to the MPLS router preferred (may be for a higher local preference or other BGP attribute).
    If so, all you need to do is to make the other default router preferred for example using a route-map applied inbound to european upstream provider to make it better ( for example increasing the local preference)
    ip prefix-list ONLY-DEFAULT permit 0.0.0.0/0
    route-map RISE-LP permit 10
    match ip address prefix ONLY-DEFAULT
    set local-preference 2000
    route-map RISE-LP permit 20
    router bgp
    neigh x.x.x.x route-map RISE-LP in
    where x.x.x.x is the eBGP peer with european upstream provider.
    Note:
    if you are receiving full internet table from both US and Europe the matter is different and can be solved by increasing the local preference for ALL routes received by the EU upstream provider.
    Hope to help
    Giuseppe
    thank you but i am a bit lost here i only see 1 entry for Ebgp advertisement
    EDCNWR01#sh ip route 0.0.0.0
    Routing entry for 0.0.0.0/0, supernet
      Known via "eigrp 729", distance 170, metric 256512, candidate default path, type external
      Redistributing via eigrp 729, bgp 10201
      Advertised by bgp 10201 route-map EIGRP_to_BGP
      Last update from 10.200.1.45 on GigabitEthernet0/0, 2d20h ago
      Routing Descriptor Blocks:
      * 10.200.1.45, from 10.200.1.45, 2d20h ago, via GigabitEthernet0/0
          Route metric is 256512, traffic share count is 1
          Total delay is 20 microseconds, minimum bandwidth is 10000 Kbit
          Reliability 255/255, minimum MTU 1500 bytes
          Loading 14/255, Hops 1
    EDCNWR01#sh ip bgp 0.0.0.0
    BGP routing table entry for 0.0.0.0/0, version 2
    Paths: (1 available, best #1, table Default-IP-Routing-Table)
      Advertised to update-groups:
      Local
        10.200.1.45 from 0.0.0.0 (10.200.248.5)
          Origin IGP, metric 256512, localpref 100, weight 32768, valid, sourced, local, best
    EDCNWR01#sh int gig 0/0
    GigabitEthernet0/0 is up, line protocol is up
      Hardware is BCM1125 Internal MAC, address is 0016.9dae.6290 (bia 0016.9dae.6290)
      Description: EDCNCS01 G1/0/19
      Internet address is 10.200.1.46/30
      MTU 1500 bytes, BW 100000 Kbit/sec, DLY 10 usec,
         reliability 255/255, txload 50/255, rxload 13/255
      Keepalive set (10 sec)
      Full-duplex, 1000Mb/s, media type is RJ45
      output flow-control is XON, input flow-control is XON
      Last input 00:00:01, output 00:00:00, output hang never
      Queueing strategy: fifo
      Output queue: 0/40 (size/max)
      30 second input rate 5219000 bits/sec, 2771 packets/sec
      30 second output rate 19978000 bits/sec, 5963 packets/sec
         3827870597 packets input, 3519855868 bytes, 0 no buffer
         Received 972089 broadcasts, 0 runts, 0 giants, 0 throttles
         5 input errors, 0 CRC, 0 frame, 5 overrun, 0 ignored
         0 watchdog, 1315440 multicast, 0 pause input
         2428111976 packets output, 1523567793 bytes, 0 underruns
         2 output errors, 0 collisions, 1 interface resets
         0 unknown protocol drops
         2 lost carrier, 0 no carrier, 0 pause output
    EDCNWR01#sh int desc
    Interface                      Status         Protocol Description
    Gi0/0                          up             up       EDCNCS01 G1/0/19
    Gi0/1                          up             up       EDCNCS02 G1/0/20
    Fa0/0/0                        up             up
    Fa0/0/0.2                      up             up       Verizon MPLS VPN: HexionSpecialtyChem; Site-Circuit: oude-meer-nld_w0w89730-1929016
    Fa0/0/1                        up             down
    Se1/0                          admin down     down     Sprint PL# 499948 E3# 68181915 KPN V205276
    Lo0                            up             up
    EDCNWR01#sh ip bgp summ
    BGP router identifier 10.200.248.5, local AS number 10201
    BGP table version is 139068, main routing table version 139068
    978 network entries using 117360 bytes of memory
    983 path entries using 51116 bytes of memory
    102/100 BGP path/bestpath attribute entries using 12648 bytes of memory
    91 BGP AS-PATH entries using 2232 bytes of memory
    0 BGP route-map cache entries using 0 bytes of memory
    0 BGP filter-list cache entries using 0 bytes of memory
    Bitfield cache entries: current 2 (at peak 2) using 60 bytes of memory
    BGP using 183416 total bytes of memory
    BGP activity 11888/10910 prefixes, 69370/68387 paths, scan interval 60 secs
    Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
    68.139.83.65    4 65000  163918   58577   139067    0    0 2w5d          849
    EDCNWR01#
    Hi, Please share Topology Diagram with interface details and BGP config...
    Check import and export policy.. Maybe the European data centre has not a valid membership for the Internet VRF ..
    Hth
    Alessio
