Default & Static Routes in Cisco 3524 Switch
Hi Friends,
I have a 3524 Switch with IOS c3500XL-c3h2s-mz-112.8.2-SA6.bin.
I want to enable default and static route commands by using "ip route" command. but it's not supporting the same.
Can any one advice me why it is not supporting (I belive it's IOS Issue) and give me the alternate solution..
Thx,
limat..
2 Accepted Solutions
Bastien Migette
The 3524 is not a MLS (layer 3 routing capable device), so use ip default-gateway instead.
bastien
glen.grant
The 3524 is a layer 2 device only and will not do any routing .  The address on the switch is used to manage the switch only and ip default gateway  is used to get to the L3 routing device for the management address . You will need a L3 device (router or L2/3 switch)  to do any routing .
Bastien Migette
bastien
glen.grant
