Delay down timer & Frequency timer interaction with IP SLA during a failed SLA check
Dean Romanelli
Level 8
Level 8
Hi All,
So I have the following IP SLA configured:
ip sla 2
icmp-echo 75.xxx.xxx.82
timeout 1000
threshold 1000
frequency 5
ip sla schedule 2 life forever start-time now
track 101 ip sla 2 reachability
delay down 7 up 180
ip route 192.168.90.0 255.255.255.0 198.168.3.1 track 101
ip route 192.168.90.0 255.255.255.0 192.168.3.2 251
Let's assume the SLA check fails. The delay down timer then starts, which I have configured to fail over in 7 seconds if no packet replies are seen. I have my frequency timer in the SLA set to check status every 5 seconds.  How do the status pings work during those 7 seconds of delay? Will my device continuously ping the target every second (since my timeout is 1000ms) during that 7 second duration, or will it only send out another single status ping when the frequency timer comes up again in 5 more seconds? If it is the latter, then essentially the above configuration means if my SLA fails 2 consecutive sanity checks (i.e. 2 ping fails in a row total), then it will fail over.  Is that correct? Below I've typed both theories out by the second to help with the concept:
Option A (In seconds):
5 ----> Check SLA status
6 ----> SLA Ping failed (on second 6 because timeout is 1000ms)
1 ----> Delay down timer of 7 seconds starts
7 ----> Delay down timer expires ---> failover to backup route
-or-
Option B (In seconds):
2 ----> Ping target.
3 ----> No reply.
4 ----> Ping target.
5 ----> No reply.
6 ----> Ping target.
7 ----> No reply. Delay down timer expires. Failover to backup route.
Jon Marshall
Dean
Without actually testing it my understanding is that when the ping fails you wait 7 seconds because of your delay timer.
Your frequency is 5 seconds so after the first ping fails you wait 5 seconds to send the next ping.
The timeout is not how often pings are sent, it is simply how long you are prepared to wait for a response to an ICMP request.
As far as I know whether the ping is successful or not it does not change the frequency of pings it sends and that is the key value here.
Jon
Jon Marshall
Dean
Jon
Thanks Jon.  I had thought that to be the case as well.  Appreciate your reply.
