Deploying Virtual Stackwise Catalyst 9400
V120311
Frequent Visitor
Frequent Visitor
   I am looking into deploying Virtual Stackwise on the Catalyst 9400 series switches. I wanted to know based on best practices where should the VSL links be deployed on the Sups or the modules? Is there a Cisco document which documents this?
Thank you,
Victor
Leo Laohoo
It doesn't matter if the VSL link is in the same slot as the supervisor card or not.
Okay, I just wanted to double check from a best practice point of view and HA point of view would it best to deploy on the modules in comparison to the supervisor ports.
here is simple deployment guide  for reference if not come across.
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.pdf
BB
