Design problem
r_cevat001
Community Member
i have 5- 2960 switches how can connect them to a router and which model should i use the 1800 series or 2800 series to make these switches talk to each orther . i'm using a video cameras so there is alot of bandwith.
Thanks all
If you want multiple VLANs on your access switches then you must use trunks (or multiple uplinks each on a different VLAN - not very efficient). For VLAN's you can either use VTP (not recommended) or statically define them on each switch (preferred). If you only have one layer-3 switch there is no need for a routing protocol as it doesn't acheive anything as a routing protocol only comes into play when there are multiple routers.
L3 switch - 3750:
ip routing
ip multicast-routing
vtp mode transparent
vlan 10
vlan 11
vlan 20
vlan 21
vlan 100
vlan 200
interface GigabitEthernet1/0/1
description to 2960-1
switchport trunk native vlan 100
switchport trunk allowed vlan 10-11
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
description to 2960-2
switchport trunk native vlan 200
switchport trunk allowed vlan 20-21
interface vlan 10
description 2960-VLAN-10
ip address 10.10.10.254 255.255.255.0
ip pim sparse-mode
interface vlan 11
description 2960-VLAN-11
ip address 10.10.11.254 255.255.255.0
ip pim sparse-mode
interface vlan 20
description 2960-VLAN-20
ip address 10.10.20.254 255.255.255.0
ip pim sparse-mode
interface vlan 21
description 2960-VLAN-21
ip address 10.10.21.254 255.255.255.0
ip pim sparse-mode
!!!!!! 2960-1 !!!!!!
vlan 10
vlan 11
vlan 100
description Uplink to 3750
interface vlan 10
description management
ip address 10.10.10.250 255.255.255.0
ip default-gateway 10.10.10.254
This would get you going. It gets a bit more complicated if you introduce additional layer-3 devices as they need to 'tell' each other about routes etc.
Andy
5 Replies 5
williamsdo
Level 5
Level 5
Hi, I would connect the switches together through the gigabit ports for high bandwidth, i would trunk these port from switch to switch you can remove any vlan traffic you dont want to cross the trunk link. Connect the first switch to your router to route traffic to other network segments. I would go with the 1841 router you have two WIC card slots and multible ethernet ports if you like to connect all your switches directly into the router.
Hi thank you for answering my inquiry. there are some issues remaining.
1- i need more thatn 100 Mbps between the switch and the router (i have video streams)
is it possible to have a 1 gigabit between the router and the switch ?
2- is there any documentation with detailed diagrams showing how to connect switch to switch and switch to router
3- Is it possible to connect the switch uplink to the router
that will be all for now
thank you William
I would suggest using a Layer-3 switch to route between the VLAN's instead of a router if the traffic rate will be high. A Catalyst 3560 or 3750 would be ideal, however for redundancy I would probably install two and connect each 2960 back to each one. Have a read of the design guides for campus networks on the SRND page:
http://www.cisco.com/go/srnd
Andy
Dear nady
thank you for your reply.
ok, lets say that i have 5 X 2960 each one is a separate VLAN
and i don't (lets assume ) redundancy.
can you give me a complete setup of these 2960 switches and L3 switch.
things like
1-vlan definition
2-routing (ospf)
3-multicast routing
4- ip addressing
the necessary things to make ip routing between vlans possible
do i need trunking too. and what about the uplinks ?
sorry for asking too much
thank again andy
L3 switch - 3750:
ip routing
vlan 10
vlan 11
vlan 20
vlan 21
vlan 100
vlan 200
interface vlan 10
ip pim sparse-mode
interface vlan 11
ip pim sparse-mode
interface vlan 20
ip pim sparse-mode
interface vlan 21
ip pim sparse-mode
vlan 10
vlan 11
vlan 100
interface vlan 10
Andy
