03-15-2021 05:04 AM
I cannot send pings across routers PC to PC. I dont know whats wrong but in the simulation mode, in show that the packets get rejected by some sort of an ICMP.
Solved! Go to Solution.
03-16-2021 12:41 AM
you have no routing at all (static or dynamic) on either of your routers. I have added EIGRP on both routers, you could use RIPv2, OSPF, or static routing as well, depending on your requirements.
Attached the revised. working file with end to end connectivity.
03-15-2021 06:06 AM - edited 03-15-2021 06:06 AM
Hello @drenzasludi38493
ICMP "Destination host unreachable" means the router/layer3 device doesn't have a route to the destination. Please verify the routing table of the router/Layer3 device sending "Destination host unreachable"
***Please rate all helpful posts***
03-15-2021 06:09 AM
what version did you save this file in ? Can you save it is .pkt and post the zipped file ?
03-15-2021 09:39 PM
03-16-2021 12:41 AM
