Device experiencing high memory utilization 9300 switch
We are receiving notification on DNA that one of our switches utilizes high memory. Anyone can suggest to me what could be the reason.
Watch Model: 9300-48 with stack and only 832 only free please see the screenshot. Thanks
26 Replies 26
balaji.bandi
what version of code running the device,
post below information :
show version
show process CPU sorted | ex 0.00
BB
Please find the command result in the attached file and the code is 16.9.4
Post the complete output to the following commands:
sh version
sh platform resources
sh platform software status control-processor brief
Sure, Here is the screenshot and version information.
Processor Pool Total: 1452962416 Used:  385414712 Free: 1067547704
 lsmpi_io Pool Total:    6295128 Used:    6294296 Free:        832
 PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  474130496  161235976  290660272       5131 2104616155 *Init*
   0   0        576 7660247320        576          0          0 *Sched*
   0   0 1969279609648 1965410970328    1639936     186356     153705 *Dead*
   0   0          0          0     986256          0          0 *MallocLite*
   1   0  588065368  583474480    3132032          0          0 Chunk Manager
   2   0        448        448      17944          0          0 Load Meter
   3   0   29853200   19202672      29944      48404      48404 SpanTree Helper
   4   0    4690624    1068056    2432656       1252       1252 RF Slave Main Th
   5   0          0          0      29944          0          0 Retransmission o
   6   0      30648          0      29944          0          0 IPC ISSU Dispatc
   7   0          0          0      29944          0          0 RO Notify Timers
   8   0          0          0      29944          0          0 VIDB BACKGD MGR
   9   0       6240        448      35736          0          0 Check heaps
  10   0 36335996872 36335725904     216032         51          0 Pool Manager
  11   0          0          0      29944          0          0 DiscardQ Backgro
  12   0        448        448      29944          0          0 Timers
  13   0          0          0      17944          0          0 WATCH_AFS
sh platform software status control-processor brief result attached and resource platform as well. Thanks
Please follow instructions.
I want to see the complete output to the following commands:
sh version
(Remove the hostname.  I want to see EVERYTHING.)
Next, I want to only see the "first page" -- Do not send the complete output.  First page only.
sh processes memory platform sorted location r0
Refrain from using this command for troubleshooting memory/CPU utilization on platform (routers, switches, WLC) that are on IOS-XE.  This command will provide inaccurate information.
A 9300 switch has 8 CPUs and this command is the average CPU for all CPUs from all switch members.
Sure agreed, but still that command works and show you some evidence right.
BB
That is a trick question.
Does the command work?  Yes, it does.
Does it show any evidence?  Yes, the wrong ones.
Look at the attached file, particularly 4.PNG. The output to the command "sh platform resources" shows switch 1 has a memory utilization of 93% and Switch 2 is 68%.  CPU utilization, per CPU, is normal with no signs of hot-spinning.
Thank you. the current version we are using is 16.9.4 and here is below command result.
Result:
CPU utilization for five seconds: 2%/0%; one minute: 3%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
618 97937155 3518271193 0 0.31% 0.30% 0.29% 0 IP SLAs XOS Even
626 19880057 2517024511 0 0.15% 0.20% 0.21% 0 BFD PP Process
114 15802364 20291158 778 0.15% 0.05% 0.05% 0 Crimson flush tr
2 1739514 6282464 276 0.07% 0.00% 0.00% 0 Load Meter
157 3323338 8436751 393 0.07% 0.01% 0.00% 0 FEP background p
82 17534968 267899479 65 0.07% 0.05% 0.05% 0 IOSD ipc task
596 4673781 156832897 29 0.07% 0.01% 0.00% 0 ONEP Network Ele
156 11871940 58778314 201 0.07% 0.03% 0.02% 0 PLFM-MGR IPC pro
397 5989999 489855406 12 0.07% 0.02% 0.00% 0 MMA DB TIMER
253 13654151 37085179 368 0.07% 0.03% 0.04% 0 CDP Protocol
39 3415140 26772075 127 0.07% 0.00% 0.00% 0 ARP Input
630 241 973 247 0.07% 0.02% 0.00% 2 SSH Process
588 1135559 122551549 9 0.07% 0.00% 0.00% 0 CCM Subscriber P
604 22083230 96346194 229 0.07% 0.06% 0.07% 0 LLDP Protocol
127 16275761 1940368898 8 0.07% 0.06% 0.06% 0 L2 LISP Punt Pro
116 22620414 182975170 123 0.07% 0.06% 0.07% 0 Crimson config p
100 2660798 59357891 44 0.07% 0.01% 0.00% 0 cpf_process_tpQ
18 0 1 0 0.00% 0.00% 0.00% 0 Graceful Reload
17 1 11 90 0.00% 0.00% 0.00% 0 ifIndex Receive
19 0 1 0 0.00% 0.00% 0.00% 0 GR Dummy Client
20 0 1 0 0.00% 0.00% 0.00% 0 CEF MIB API
23 272295 30665743 8 0.00% 0.00% 0.00% 0 IPC Mcast Pendin
16 0 1 0 0.00% 0.00% 0.00% 0 DB Notification
25 3212 523536 6 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
21 0 40 0 0.00% 0.00% 0.00% 0 IPC Apps Task
22 37431 6281945 5 0.00% 0.00% 0.00% 0 IPC Event Notifi
28 307806 31788475 9 0.00% 0.00% 0.00% 0 IPC Periodic Tim
24 0 1 0 0.00% 0.00% 0.00% 0 Platform appsess
30 0 1 0 0.00% 0.00% 0.00% 0 IPC Process leve
31 454526 10212152 44 0.00% 0.00% 0.00% 0 IPC Seat Manager
32 13988 1797713 7 0.00% 0.00% 0.00% 0 IPC Check Queue
33 166012 2338559 70 0.00% 0.00% 0.00% 0 IPC Seat RX Cont
26 42661 6281946 6 0.00% 0.00% 0.00% 0 IPC Service NonC
35 120851 3141233 38 0.00% 0.00% 0.00% 0 IPC Keep Alive M
36 465349 6281954 74 0.00% 0.00% 0.00% 0 IPC Loadometer
15 778476 21746642 35 0.00% 0.00% 0.00% 0 DB Lock Manager
38 0 1 0 0.00% 0.00% 0.00% 0 SENSOR-MGR event
27 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
29 251577 30665742 8 0.00% 0.00% 0.00% 0 IPC Deferred Por
41 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
42 0 1 0 0.00% 0.00% 0.00% 0 ATM ASYNC PROC
43 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
44 20 25 800 0.00% 0.00% 0.00% 0 Entity MIB API
14 132834 15703549 8 0.00% 0.00% 0.00% 0 IOSXE heartbeat
46 4 12 333 0.00% 0.00% 0.00% 0 PrstVbl
47 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
48 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
49 0 1 0 0.00% 0.00% 0.00% 0 AAA_SERVER_DEADT
50 0 1 0 0.00% 0.00% 0.00% 0 Policy Manager
51 0 1 0 0.00% 0.00% 0.00% 0 IOSXE signals IO
52 306161 31412313 9 0.00% 0.00% 0.00% 0 GraphIt
53 306772 31400965 9 0.00% 0.00% 0.00% 0 Dynamic ARP Insp
34 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat TX Cont
37 0 1 0 0.00% 0.00% 0.00% 0 IPC Session Deta
56 0 1 0 0.00% 0.00% 0.00% 0 License IPC stat
57 0 1 0 0.00% 0.00% 0.00% 0 License IPC serv
58 6033 598248 10 0.00% 0.00% 0.00% 0 Net Input
59 1 6 166 0.00% 0.00% 0.00% 0 client_entity_se
60 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
61 0 2 0 0.00% 0.00% 0.00% 0 XML Proxy Client
12 0 2 0 0.00% 0.00% 0.00% 0 Timers
63 0 2 0 0.00% 0.00% 0.00% 0 License Client N
64 79477 6993007 11 0.00% 0.00% 0.00% 0 BFD
13 35329 8605449 4 0.00% 0.00% 0.00% 0 WATCH_AFS
66 1 4 250 0.00% 0.00% 0.00% 0 SASConnect
40 422117 36182926 11 0.00% 0.00% 0.00% 0 ARP Background
11 0 1 0 0.00% 0.00% 0.00% 0 DiscardQ Backgro
69 251967 21077038 11 0.00% 0.00% 0.00% 0 SACRcvWQ
70 0 1 0 0.00% 0.00% 0.00% 0 Image License br
71 40142 1047064 38 0.00% 0.00% 0.00% 0 Licensing Auto U
72 0 1 0 0.00% 0.00% 0.00% 0 License HA Consi
73 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
74 11890672 152697400 77 0.00% 0.04% 0.04% 0 Net Background
75 0 3 0 0.00% 0.00% 0.00% 0 IDB Work
76 35510 2021011 17 0.00% 0.00% 0.00% 0 Logger
77 476877 31400952 15 0.00% 0.00% 0.00% 0 TTY Background
78 0 2 0 0.00% 0.00% 0.00% 0 NGWC SGT-Cache p
10 33747 523593 64 0.00% 0.00% 0.00% 0 Pool Manager
9 13080404 4299940 3041 0.00% 0.02% 0.00% 0 Check heaps
45 0 1 0 0.00% 0.00% 0.00% 0 IFS Agent Manage
54 1593415 26785786 59 0.00% 0.00% 0.00% 0 ARP Snoop
83 124492 8416249 14 0.00% 0.00% 0.00% 0 IOSD chasfs task
84 0 3 0 0.00% 0.00% 0.00% 0 NGWC OIR CC Proc
85 0 1 0 0.00% 0.00% 0.00% 0 MATM SPI client
86 10 9 1111 0.00% 0.00% 0.00% 0 NGWC_OIRSHIM_TAS
87 0 1 0 0.00% 0.00% 0.00% 0 Ng3k envvar sync
88 47460 4487257 10 0.00% 0.00% 0.00% 0 REDUNDANCY FSM
89 0 1 0 0.00% 0.00% 0.00% 0 Punt FP Stats Du
90 1586002 15702772 101 0.00% 0.00% 0.00% 0 PuntInject Keepa
91 9 90 100 0.00% 0.00% 0.00% 0 IF-MGR control p
92 426 15827 26 0.00% 0.00% 0.00% 0 IF-MGR event pro
93 0 8 0 0.00% 0.00% 0.00% 0 CTS HA
94 0 4 0 0.00% 0.00% 0.00% 0 CTS HA IPC flow
95 0 1 0 0.00% 0.00% 0.00% 0 CTS HA operation
96 266130 33319810 7 0.00% 0.00% 0.00% 0 Environmental Mo
97 316123 31400966 10 0.00% 0.00% 0.00% 0 RP HA Periodic
98 0 3 0 0.00% 0.00% 0.00% 0 cpf_msg_holdq_pr
99 643 23042 27 0.00% 0.00% 0.00% 0 cpf_msg_rcvq_pro
55 7 39 179 0.00% 0.00% 0.00% 0 SL Platform Back
101 0 1 0 0.00% 0.00% 0.00% 0 CONSOLE helper p
62 187524944 16465554 11388 0.00% 0.75% 1.10% 0 crypto sw pk pro
103 1 19 52 0.00% 0.00% 0.00% 0 EM_SHIM_NOTIFY_T
104 0 1 0 0.00% 0.00% 0.00% 0 NGWC Configurati
105 0 3 0 0.00% 0.00% 0.00% 0 MATM CF Flow Con
106 451228 8643302 52 0.00% 0.00% 0.00% 0 NGWC Learning Pr
107 0 3 0 0.00% 0.00% 0.00% 0 ACCESS_TUNNEL CF
108 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping cl
109 19943 333962 59 0.00% 0.00% 0.00% 0 DHCP Snooping
110 0 1 0 0.00% 0.00% 0.00% 0 DHCP Snooping db
111 1841 12444 147 0.00% 0.00% 0.00% 0 DHCP Snooping HA
112 2 5 400 0.00% 0.00% 0.00% 0 STACK MGR Proces
113 375559 5017289 74 0.00% 0.00% 0.00% 0 ARP HA
5 0 114 0 0.00% 0.00% 0.00% 0 Retransmission o
115 3587 16270 220 0.00% 0.00% 0.00% 0 DBAL EVENTS
65 2444506 7448322 328 0.00% 0.00% 0.00% 0 SAStorage
117 0 3 0 0.00% 0.00% 0.00% 0 NGWC ILP CF Proc
118 0 5 0 0.00% 0.00% 0.00% 0 CEF RRP RF waite
119 2127642 55916462 38 0.00% 0.00% 0.00% 0 REDUNDANCY peer
120 2984764 313999544 9 0.00% 0.00% 0.00% 0 100ms check
121 0 2 0 0.00% 0.00% 0.00% 0 Network-rf Notif
122 0 1 0 0.00% 0.00% 0.00% 0 XDR RRP RF waite
67 289889 20787312 13 0.00% 0.00% 0.00% 0 SASRcvWQ
124 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP Punt IP
125 0 1 0 0.00% 0.00% 0.00% 0 ACL Log Punt Ser
126 0 1 0 0.00% 0.00% 0.00% 0 ACL deny punt se
68 0 5 0 0.00% 0.00% 0.00% 0 SACConnect
128 0 1 0 0.00% 0.00% 0.00% 0 OFSDN Punject Pr
79 396468 2087352 189 0.00% 0.00% 0.00% 0 CTS CORE
130 0 3 0 0.00% 0.00% 0.00% 0 CWAN APS HA Proc
131 1 7 142 0.00% 0.00% 0.00% 0 DHCPD HA
132 0 7 0 0.00% 0.00% 0.00% 0 DHCPC HA
133 0 8 0 0.00% 0.00% 0.00% 0 DHCPv6 Relay HA
134 0 8 0 0.00% 0.00% 0.00% 0 DHCPv6 Server HA
135 0 3 0 0.00% 0.00% 0.00% 0 SISF HA Process
136 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-HA
137 106628 7852830 13 0.00% 0.00% 0.00% 0 RF Master Main T
138 843356 7852203 107 0.00% 0.00% 0.00% 0 RF Master Status
139 226207 15702758 14 0.00% 0.00% 0.00% 0 SACRcvWQWrk1
140 242823 15702762 15 0.00% 0.00% 0.00% 0 SACRcvWQWrk2
141 235319 15776024 14 0.00% 0.00% 0.00% 0 SACRcvWQWrk3
142 594236 20787212 28 0.00% 0.00% 0.00% 0 SASRcvWQWrk2
143 136 32142 4 0.00% 0.00% 0.00% 0 BACK CHECK
144 0 1 0 0.00% 0.00% 0.00% 0 PKI Trustpool
145 102669271 24807600 4138 0.00% 0.68% 0.63% 0 SAMsgThread
146 1621967 3551229 456 0.00% 0.00% 0.00% 0 Compute load avg
147 4917202 1113665 4415 0.00% 0.01% 0.00% 0 Per-minute Jobs
148 1119587 35286559 31 0.00% 0.00% 0.00% 0 Per-Second Jobs
149 0 1 0 0.00% 0.00% 0.00% 0 AggMgr Process
80 239380 15702825 15 0.00% 0.00% 0.00% 0 SASRcvWQWrk1
151 18204 1669095 10 0.00% 0.00% 0.00% 0 Transport Port A
81 5492 230879 23 0.00% 0.00% 0.00% 0 SXP CORE
153 0 1 0 0.00% 0.00% 0.00% 0 IOSXE-RP FastPat
8 6816 1047065 6 0.00% 0.00% 0.00% 0 VIDB BACKGD MGR
155 0 1 0 0.00% 0.00% 0.00% 0 ngpm main proces
7 0 1 0 0.00% 0.00% 0.00% 0 RO Notify Timers
6 0 2 0 0.00% 0.00% 0.00% 0 IPC ISSU Dispatc
3 2943 8117 362 0.00% 0.00% 0.00% 0 SpanTree Helper
102 321 56326 5 0.00% 0.00% 0.00% 0 EM_SHIM_TASK
160 70626 103617 681 0.00% 0.00% 0.00% 0 NGWC L2M
161 1464467 8360757 175 0.00% 0.00% 0.00% 0 Thermal backgrou
162 2850 523536 5 0.00% 0.00% 0.00% 0 MMN bkgrd proces
163 30348 16367 1854 0.00% 0.00% 0.00% 0 NGWC DOT1X Proce
164 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Identity
165 0 1 0 0.00% 0.00% 0.00% 0 Remote Console P
166 0 1 0 0.00% 0.00% 0.00% 0 ACL Logging Proc
167 11 7 1571 0.00% 0.00% 0.00% 0 NGWC_MACSEC_IOSD
168 1340004 5798543 231 0.00% 0.00% 0.00% 0 Inline Power
169 0 1 0 0.00% 0.00% 0.00% 0 Src Fltr backgro
170 0 1 0 0.00% 0.00% 0.00% 0 FPD Management P
171 0 1 0 0.00% 0.00% 0.00% 0 FPD Action Proce
172 249859 30665741 8 0.00% 0.00% 0.00% 0 fanrp_l2fib
173 0 4 0 0.00% 0.00% 0.00% 0 EEM ED MAT
174 656352 50622614 12 0.00% 0.00% 0.00% 0 EEM ED ND
175 253207 6281338 40 0.00% 0.00% 0.00% 0 MGMTE stats Proc
176 0 1 0 0.00% 0.00% 0.00% 0 Connection Mgr
177 1495806 4958821 301 0.00% 0.00% 0.00% 0 MATM RP Shim Pro
178 14 2 7000 0.00% 0.00% 0.00% 0 CWAN OIR Handler
179 0 1 0 0.00% 0.00% 0.00% 0 TP CUTOVER EVENT
180 0 1 0 0.00% 0.00% 0.00% 0 RTTYS Process
181 0 2 0 0.00% 0.00% 0.00% 0 Ethernet OAM Pro
182 0 2 0 0.00% 0.00% 0.00% 0 Ethernet CFM
183 21888 3141119 6 0.00% 0.00% 0.00% 0 Ethchnl
184 0 2 0 0.00% 0.00% 0.00% 0 MVRP Process
185 156469 739680 211 0.00% 0.00% 0.00% 0 mcprp callhome p
186 0 1 0 0.00% 0.00% 0.00% 0 Switch Backup In
187 0 2 0 0.00% 0.00% 0.00% 0 SNMP DBAL WRAPPE
188 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
189 0 1 0 0.00% 0.00% 0.00% 0 SNMP DBAL Cache
190 6 75 80 0.00% 0.00% 0.00% 0 EPM IAL Process
191 0 2 0 0.00% 0.00% 0.00% 0 REP Topology cha
192 0 2 0 0.00% 0.00% 0.00% 0 FMANRP REP Helpe
193 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Hello Pr
194 1 2 500 0.00% 0.00% 0.00% 0 SKA IPC process
195 0 18 0 0.00% 0.00% 0.00% 0 NGWC led process
196 209092 2356941 88 0.00% 0.00% 0.00% 0 PI MATM Aging Pr
197 8478 523592 16 0.00% 0.00% 0.00% 0 Port-Security
198 0 4 0 0.00% 0.00% 0.00% 0 DTP Protocol
123 5906534 141477344 41 0.00% 0.01% 0.00% 0 IOSXE-RP Punt Se
200 0 1 0 0.00% 0.00% 0.00% 0 L2LISP XID Proce
201 0 2 0 0.00% 0.00% 0.00% 0 CDP Forward Proc
202 692913 31400962 22 0.00% 0.00% 0.00% 0 FHRP Main thread
203 0 1 0 0.00% 0.00% 0.00% 0 TRACK Main threa
204 0 1 0 0.00% 0.00% 0.00% 0 TRACK Client thr
205 0 1 0 0.00% 0.00% 0.00% 0 VRRP Main thread
206 6096000 489855814 12 0.00% 0.01% 0.00% 0 VRRS Main thread
207 6 1 6000 0.00% 0.00% 0.00% 0 PKI/SSL IPC proc
208 1 2 500 0.00% 0.00% 0.00% 0 PKI_SSL LSC Enro
209 0 1 0 0.00% 0.00% 0.00% 0 PPCP RP Stats Ba
210 0 2 0 0.00% 0.00% 0.00% 0 CEF switching ba
211 0 1 0 0.00% 0.00% 0.00% 0 ADJ NSF process
212 3563148 47093638 75 0.00% 0.00% 0.00% 0 MKA
213 0 1 0 0.00% 0.00% 0.00% 0 Spanning Tree St
214 8 2 4000 0.00% 0.00% 0.00% 0 PTP protocol eng
215 0 1 0 0.00% 0.00% 0.00% 0 L2FIB Timer Disp
216 374706 7703444 48 0.00% 0.00% 0.00% 0 MLRIB L2 Msg Thr
217 0 2 0 0.00% 0.00% 0.00% 0 NVE main thread
218 396738 30672959 12 0.00% 0.00% 0.00% 0 L2RIB Thread
219 0 1 0 0.00% 0.00% 0.00% 0 HQF TARGET DYNAM
220 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
221 8572243 1057440320 8 0.00% 0.02% 0.00% 0 IPAM Manager
222 0 2 0 0.00% 0.00% 0.00% 0 IPAM Events
223 2015 12931 155 0.00% 0.00% 0.00% 0 IP ARP Adjacency
224 7878548 974854174 8 0.00% 0.03% 0.01% 0 IP ARP Retry Age
225 712236 6039773 117 0.00% 0.00% 0.00% 0 IP Input
226 1953 524464 3 0.00% 0.00% 0.00% 0 ICMP event handl
227 367441 33351686 11 0.00% 0.00% 0.00% 0 mDNS
228 701116 12714710 55 0.00% 0.00% 0.00% 0 DiagCard2/-1
229 0 1 0 0.00% 0.00% 0.00% 0 AAA EPD HANDLER
230 0 1 0 0.00% 0.00% 0.00% 0 PM EPD API
231 0 2 0 0.00% 0.00% 0.00% 0 PPP SIP
232 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
233 0 2 0 0.00% 0.00% 0.00% 0 PPP IP Route
234 112 15669 7 0.00% 0.00% 0.00% 0 SSM connection m
235 3014 523536 5 0.00% 0.00% 0.00% 0 SSS Manager
236 0 1 0 0.00% 0.00% 0.00% 0 SSS Policy Manag
237 0 1 0 0.00% 0.00% 0.00% 0 SSS Feature Mana
238 1268876 122715452 10 0.00% 0.00% 0.00% 0 SSS Feature Time
239 20586066 66659153 308 0.00% 0.06% 0.07% 0 Spanning Tree
240 0 2 0 0.00% 0.00% 0.00% 0 SpanTree Msg
129 0 4 0 0.00% 0.00% 0.00% 0 IOSXE-RP SPA TSM
242 0 1 0 0.00% 0.00% 0.00% 0 VRRS
243 0 1 0 0.00% 0.00% 0.00% 0 O-UNI Client Msg
244 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM Input
245 0 2 0 0.00% 0.00% 0.00% 0 ATM OAM TIMER
246 0 11 0 0.00% 0.00% 0.00% 0 CCM
247 0 4 0 0.00% 0.00% 0.00% 0 CCM IPC flow con
248 0 1 0 0.00% 0.00% 0.00% 0 Timer handler fo
249 0 1 0 0.00% 0.00% 0.00% 0 Prepaid response
250 0 1 0 0.00% 0.00% 0.00% 0 Timed Policy act
251 0 1 0 0.00% 0.00% 0.00% 0 AAA response han
252 0 2 0 0.00% 0.00% 0.00% 0 Maintenance mode
150 66397 850166 78 0.00% 0.00% 0.00% 0 ACT2 Crypto Engi
254 0 1 0 0.00% 0.00% 0.00% 0 WSMA_NOTIFY
255 11744 523537 22 0.00% 0.00% 0.00% 0 Call Home Timer
256 0 1 0 0.00% 0.00% 0.00% 0 radius radsec cl
257 856 89263 9 0.00% 0.00% 0.00% 0 AAA Server
258 0 1 0 0.00% 0.00% 0.00% 0 AAA ACCT Proc
259 1 1 1000 0.00% 0.00% 0.00% 0 ACCT Periodic Pr
260 0 2 0 0.00% 0.00% 0.00% 0 AAA Dictionary R
261 240560 17169909 14 0.00% 0.00% 0.00% 0 SACRcvWQWrk4
262 0 5 0 0.00% 0.00% 0.00% 0 TurboACL
263 0 2 0 0.00% 0.00% 0.00% 0 TurboACL chunk
264 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ping proces
265 0 1 0 0.00% 0.00% 0.00% 0 st_pw_oam
266 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
267 0 1 0 0.00% 0.00% 0.00% 0 LSP Tunnel FRR
268 0 3 0 0.00% 0.00% 0.00% 0 MPLS Auto-Tunnel
269 0 2 0 0.00% 0.00% 0.00% 0 OCE punted Pkts
270 0 3 0 0.00% 0.00% 0.00% 0 PIM register asy
271 0 6 0 0.00% 0.00% 0.00% 0 RIB LM VALIDATE
272 0 1 0 0.00% 0.00% 0.00% 0 XDR background p
273 102112 1403288 72 0.00% 0.00% 0.00% 0 XDR mcast
274 0 3 0 0.00% 0.00% 0.00% 0 XDR RP Ping Back
275 8251 87244 94 0.00% 0.00% 0.00% 0 XDR receive
276 0 4 0 0.00% 0.00% 0.00% 0 IPC LC Message H
277 0 1 0 0.00% 0.00% 0.00% 0 XDR RP Test Back
278 3142 523536 6 0.00% 0.00% 0.00% 0 FRR Background P
279 505840 3797903 133 0.00% 0.00% 0.00% 0 CEF background p
280 0 32 0 0.00% 0.00% 0.00% 0 fib_fib_bfd_sb e
281 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
282 0 2 0 0.00% 0.00% 0.00% 0 LSD HA Proc
283 5 33 151 0.00% 0.00% 0.00% 0 CEF RP Backgroun
284 0 2 0 0.00% 0.00% 0.00% 0 Routing Topology
285 3214 10637 302 0.00% 0.00% 0.00% 0 IP RIB Update
286 6380 598008 10 0.00% 0.00% 0.00% 0 IP Background
287 761 23873 31 0.00% 0.00% 0.00% 0 IP Connected Rou
288 0 2 0 0.00% 0.00% 0.00% 0 SPA XCVR SENSOR
289 0 2 0 0.00% 0.00% 0.00% 0 EFP Errd
290 0 2 0 0.00% 0.00% 0.00% 0 Ether EFP Proces
291 304930 31400956 9 0.00% 0.00% 0.00% 0 nbar-graph-sende
292 94650 6281945 15 0.00% 0.00% 0.00% 0 nbar-custom-prot
293 8992 523537 17 0.00% 0.00% 0.00% 0 nbar-auto-custom
152 84893 322281 263 0.00% 0.00% 0.00% 0 SFF8472
295 8919 588021 15 0.00% 0.00% 0.00% 0 nbar-pp-monitor
296 0 2 0 0.00% 0.00% 0.00% 0 Ether Infra RP
297 0 4 0 0.00% 0.00% 0.00% 0 CFM HA IPC messa
154 0 7 0 0.00% 0.00% 0.00% 0 NG Backup Interf
299 0 2 0 0.00% 0.00% 0.00% 0 Ethernet PM Soft
300 101579 9929961 10 0.00% 0.00% 0.00% 0 Ethernet PM Moni
301 0 2 0 0.00% 0.00% 0.00% 0 AUTO LAG Protoco
4 110 259 424 0.00% 0.00% 0.00% 0 RF Slave Main Th
303 0 1 0 0.00% 0.00% 0.00% 0 IGMPSN MRD
304 1388 83131 16 0.00% 0.00% 0.00% 0 IGMPSN
305 225877 2500723 90 0.00% 0.00% 0.00% 0 TCP Timer
306 9219 59316 155 0.00% 0.00% 0.00% 0 TCP Protocols
307 0 1 0 0.00% 0.00% 0.00% 0 TCP HA PROC
308 0 2 0 0.00% 0.00% 0.00% 0 REP LSL Proc
159 0 1 0 0.00% 0.00% 0.00% 0 NGWC diag proces
310 0 2 0 0.00% 0.00% 0.00% 0 AN
311 0 1 0 0.00% 0.00% 0.00% 0 AN HELPER
312 0 1 0 0.00% 0.00% 0.00% 0 AN CONFIG DOWNLO
1 2898 319337 9 0.00% 0.00% 0.00% 0 Chunk Manager
314 7902 1704184 4 0.00% 0.00% 0.00% 0 Socket Timers
158 803526 3397013 236 0.00% 0.00% 0.00% 0 XPS background p
199 9678 16090 601 0.00% 0.00% 0.00% 0 802.1x switch
317 0 1 0 0.00% 0.00% 0.00% 0 MRD
318 0 1 0 0.00% 0.00% 0.00% 0 MLD_SNOOP
319 0 1 0 0.00% 0.00% 0.00% 0 IGMPQR
320 0 4 0 0.00% 0.00% 0.00% 0 IGMPSN-HA
321 0 4 0 0.00% 0.00% 0.00% 0 MLDSN-HA
322 2045 8059 253 0.00% 0.00% 0.00% 0 VMATM Callback
323 407260 28729947 14 0.00% 0.00% 0.00% 0 DAI Packet Proce
324 224 15636 14 0.00% 0.00% 0.00% 0 Flow Exporter Ti
325 0 2 0 0.00% 0.00% 0.00% 0 Flow Exporter Pa
326 0 1 0 0.00% 0.00% 0.00% 0 Tunnel FIB
327 0 1 0 0.00% 0.00% 0.00% 0 RETRY_REPOPULATE
328 0 1 0 0.00% 0.00% 0.00% 0 LICENSE AGENT
329 0 3 0 0.00% 0.00% 0.00% 0 L2TRACE SERVER
330 0 2 0 0.00% 0.00% 0.00% 0 NEXTHOP_MAC_PROC
331 0 2 0 0.00% 0.00% 0.00% 0 Ewlc copy mqipc
332 0 2 0 0.00% 0.00% 0.00% 0 Ewlc cli mqipc h
333 0 2 0 0.00% 0.00% 0.00% 0 Tunnel
334 179417 16462301 10 0.00% 0.00% 0.00% 0 CEF: IPv4 proces
335 0 14 0 0.00% 0.00% 0.00% 0 ADJ background
336 21987 113296 194 0.00% 0.00% 0.00% 0 Collection proce
337 179643 16436922 10 0.00% 0.00% 0.00% 0 CEF: IPv6 proces
338 0 4 0 0.00% 0.00% 0.00% 0 XDR FOF process
339 444 3908 113 0.00% 0.00% 0.00% 0 ADJ resolve proc
340 0 3 0 0.00% 0.00% 0.00% 0 HSRP HA
341 0 9 0 0.00% 0.00% 0.00% 0 SNMP Timers
342 0 1 0 0.00% 0.00% 0.00% 0 IP Traceroute
343 1 15 66 0.00% 0.00% 0.00% 0 BFD HA
344 0 4 0 0.00% 0.00% 0.00% 0 STP HA IPC flow
345 753745 7559644 99 0.00% 0.00% 0.00% 0 L2FIB Event Disp
346 0 1 0 0.00% 0.00% 0.00% 0 EVPN main thread
347 1 1 1000 0.00% 0.00% 0.00% 0 NVE MGR RWATCH T
348 434 35162 12 0.00% 0.00% 0.00% 0 EVPN Mgr Thread
349 0 3 0 0.00% 0.00% 0.00% 0 EVPN HA Bulk Syn
350 4700901 30199792 155 0.00% 0.00% 0.00% 0 SISF Switcher Th
351 7249966 195684636 37 0.00% 0.03% 0.01% 0 SISF Main Thread
352 0 1 0 0.00% 0.00% 0.00% 0 COPS
353 0 3 0 0.00% 0.00% 0.00% 0 Service Routing
354 499 24822 20 0.00% 0.00% 0.00% 0 SR CapMan Proces
355 272 19253 14 0.00% 0.00% 0.00% 0 DNS Service
356 0 33 0 0.00% 0.00% 0.00% 0 static
357 0 1 0 0.00% 0.00% 0.00% 0 IPv6 RIB Cleanup
358 0 3 0 0.00% 0.00% 0.00% 0 IPv6 RIB Event H
359 1 2 500 0.00% 0.00% 0.00% 0 SCTP Main Proces
360 0 2 0 0.00% 0.00% 0.00% 0 VPWS Thread
361 0 4 0 0.00% 0.00% 0.00% 0 EVPN Thread
362 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_state_eve
363 0 1 0 0.00% 0.00% 0.00% 0 ac_atm_mraps_hsp
364 0 2 0 0.00% 0.00% 0.00% 0 VFI HA Bulk Sync
365 0 1 0 0.00% 0.00% 0.00% 0 AC HA Bulk Sync
366 0 3 0 0.00% 0.00% 0.00% 0 XC RIB MGR
367 0 3 0 0.00% 0.00% 0.00% 0 XC RIB HA Bulk S
368 0 3 0 0.00% 0.00% 0.00% 0 XC BGP SIG RIB H
369 111 8327 13 0.00% 0.00% 0.00% 0 PIM Snooping Pro
370 0 1 0 0.00% 0.00% 0.00% 0 NGWC-PIMSN Proce
371 0 1 0 0.00% 0.00% 0.00% 0 AAA System Acct
372 0 2 0 0.00% 0.00% 0.00% 0 DHCPv6 LQ client
373 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Static Hand
374 1369457 3374837 405 0.00% 0.00% 0.00% 0 QoS stats proces
375 0 1 0 0.00% 0.00% 0.00% 0 AToM HA Bulk Syn
376 0 3 0 0.00% 0.00% 0.00% 0 AToM MGR HA IPC
377 2 22 90 0.00% 0.00% 0.00% 0 LDP HA
378 0 8 0 0.00% 0.00% 0.00% 0 TSPTUN HA
379 0 3 0 0.00% 0.00% 0.00% 0 RSVP HA Services
380 0 2 0 0.00% 0.00% 0.00% 0 TE NSR OOS DB Pr
381 0 7 0 0.00% 0.00% 0.00% 0 RSVP SYNC
382 0 2 0 0.00% 0.00% 0.00% 0 LFDp Input Proc
383 0 1 0 0.00% 0.00% 0.00% 0 MFI Comm RP Proc
384 0 2 0 0.00% 0.00% 0.00% 0 LFD Label Block
385 984 15668 62 0.00% 0.00% 0.00% 0 MVPN Mgr Process
386 0 2 0 0.00% 0.00% 0.00% 0 Multicast Offloa
387 1 1 1000 0.00% 0.00% 0.00% 0 ONEP Dispatch po
388 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
389 1 7 142 0.00% 0.00% 0.00% 0 MRIB RP PROCESS
390 0 1 0 0.00% 0.00% 0.00% 0 MRIB RP Proxy
391 1219 112012 10 0.00% 0.00% 0.00% 0 MFIB Master back
392 0 3 0 0.00% 0.00% 0.00% 0 MPLS VPN HA Clie
393 665663 61313426 10 0.00% 0.00% 0.00% 0 TLSCLIENT_PROCES
394 0 1 0 0.00% 0.00% 0.00% 0 DynCmd Package P
395 0 1 0 0.00% 0.00% 0.00% 0 mDNS snooping
396 0 1 0 0.00% 0.00% 0.00% 0 EEM MLANG MANAGE
294 616184 31400956 19 0.00% 0.00% 0.00% 0 nbar-sdavc-sched
398 0 1 0 0.00% 0.00% 0.00% 0 EM Background Pr
399 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
400 0 1 0 0.00% 0.00% 0.00% 0 Key chain liveke
401 0 1 0 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
402 0 3 0 0.00% 0.00% 0.00% 0 EST Client
403 0 2 0 0.00% 0.00% 0.00% 0 AAA Cached Serve
404 0 2 0 0.00% 0.00% 0.00% 0 ENABLE AAA
405 0 3 0 0.00% 0.00% 0.00% 0 LDAP process
406 0 2 0 0.00% 0.00% 0.00% 0 LINE AAA
407 20614 1963829 10 0.00% 0.00% 0.00% 0 LOCAL AAA
408 193 31315 6 0.00% 0.00% 0.00% 0 TPLUS
409 0 71 0 0.00% 0.00% 0.00% 0 MPLS Auto Mesh P
410 0 1 0 0.00% 0.00% 0.00% 0 Opaque Database
411 665024 61313426 10 0.00% 0.00% 0.00% 0 Timer Library
412 0 2 0 0.00% 0.00% 0.00% 0 Crypto Support
413 0 1 0 0.00% 0.00% 0.00% 0 IPSECv6 PS Proc
414 3417 8726 391 0.00% 0.00% 0.00% 0 NIST rng proc
415 0 2 0 0.00% 0.00% 0.00% 0 MVRP SWITCH Proc
416 0 4 0 0.00% 0.00% 0.00% 0 COND_DEBUG HA IP
417 0 1 0 0.00% 0.00% 0.00% 0 AAA Proxy
418 0 2 0 0.00% 0.00% 0.00% 0 REP Switch Helpe
419 6 11 545 0.00% 0.00% 0.00% 0 crypto engine pr
420 0 1 0 0.00% 0.00% 0.00% 0 RSA background p
421 108 5340 20 0.00% 0.00% 0.00% 0 Crypto CA
422 1 7 142 0.00% 0.00% 0.00% 0 Crypto PKI-CRL
423 0 1 0 0.00% 0.00% 0.00% 0 Crypto PKI-Rev-P
424 0 1 0 0.00% 0.00% 0.00% 0 PKI OCSP
425 0 1 0 0.00% 0.00% 0.00% 0 PKI Revocation
426 1 1 1000 0.00% 0.00% 0.00% 0 pki_app
427 3 3 1000 0.00% 0.00% 0.00% 0 TPS IPC Process
428 0 2 0 0.00% 0.00% 0.00% 0 MMON PROCESS
429 5955366 489855525 12 0.00% 0.01% 0.00% 0 MMA DP TIMER
430 5352775 980854491 5 0.00% 0.00% 0.00% 0 MMON MENG
431 0 1 0 0.00% 0.00% 0.00% 0 EWLC/AAA IPC pro
432 0 1 0 0.00% 0.00% 0.00% 0 EWLC/AAA IPC pro
433 0 2 0 0.00% 0.00% 0.00% 0 File Copy Handle
434 0 2 0 0.00% 0.00% 0.00% 0 Lawful Intercept
435 0 2 0 0.00% 0.00% 0.00% 0 LI messaging
436 1 9 111 0.00% 0.00% 0.00% 0 PIM HA
437 0 1 0 0.00% 0.00% 0.00% 0 encrypt proc
438 1036643 32451441 31 0.00% 0.00% 0.00% 0 Crypto IKEv2
439 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 AAA handle
440 0 3 0 0.00% 0.00% 0.00% 0 CRYPTO MAP FREE
441 0 1 0 0.00% 0.00% 0.00% 0 Crypto INT
442 0 2 0 0.00% 0.00% 0.00% 0 Crypto IKE Dispa
443 1 3 333 0.00% 0.00% 0.00% 0 Crypto IKMP
444 0 1 0 0.00% 0.00% 0.00% 0 IPSEC manual key
445 0 1 0 0.00% 0.00% 0.00% 0 IPsec vesen keym
446 18531 1570586 11 0.00% 0.00% 0.00% 0 IPSEC key engine
447 1 1 1000 0.00% 0.00% 0.00% 0 Crypto ACL
448 0 1 0 0.00% 0.00% 0.00% 0 Crypto PAS Proc
449 0 1 0 0.00% 0.00% 0.00% 0 IPSec background
450 0 75 0 0.00% 0.00% 0.00% 0 VTP Trap Process
451 0 1 0 0.00% 0.00% 0.00% 0 SEP_webui_wsma_h
452 4304 270494 15 0.00% 0.00% 0.00% 0 DHCPD Timer
453 25078 2829972 8 0.00% 0.00% 0.00% 0 dhcp snooping sw
454 960 64840 14 0.00% 0.00% 0.00% 0 ASP Process Crea
455 0 1 0 0.00% 0.00% 0.00% 0 Licensing MIB pr
456 1 4 250 0.00% 0.00% 0.00% 0 EEM GED BINOS PR
457 0 2 0 0.00% 0.00% 0.00% 0 AUTO DEPLOY PROC
458 0 2 0 0.00% 0.00% 0.00% 0 DHCP Security He
459 0 4 0 0.00% 0.00% 0.00% 0 Process to do EH
460 0 1 0 0.00% 0.00% 0.00% 0 NCD Process
461 0 1 0 0.00% 0.00% 0.00% 0 Online Diag EEM
462 3401 568721 5 0.00% 0.00% 0.00% 0 SPA ENTITY Proce
463 0 1 0 0.00% 0.00% 0.00% 0 dcm_cli_engine
464 0 3 0 0.00% 0.00% 0.00% 0 dcm_cli_provider
465 0 4 0 0.00% 0.00% 0.00% 0 DCM Core Thread
466 20499 1212765 16 0.00% 0.00% 0.00% 0 EEM ED Syslog
467 1 4 250 0.00% 0.00% 0.00% 0 EEM ED Generic
468 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Routing
469 315586 441133 715 0.00% 0.00% 0.00% 0 Syslog Traps
470 2 8 250 0.00% 0.00% 0.00% 0 RFS server proce
471 1407 62364 22 0.00% 0.00% 0.00% 0 AAA SEND STOP EV
472 0 1 0 0.00% 0.00% 0.00% 0 Test AAA Client
473 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 FlexVPN Pr
474 0 1 0 0.00% 0.00% 0.00% 0 IKEv2 Cluster Lo
475 0 1 0 0.00% 0.00% 0.00% 0 ISSU Utility Pro
476 4496609 299548766 15 0.00% 0.00% 0.00% 0 PM Callback
477 0 5 0 0.00% 0.00% 0.00% 0 SPAN switch
478 0 3 0 0.00% 0.00% 0.00% 0 WSMAN Process
479 4545 523536 8 0.00% 0.00% 0.00% 0 FNF background p
480 0 3 0 0.00% 0.00% 0.00% 0 BFD events
481 0 2 0 0.00% 0.00% 0.00% 0 Inter Chassis Pr
482 12488 769772 16 0.00% 0.00% 0.00% 0 EEM Server
483 1 4 250 0.00% 0.00% 0.00% 0 EEM ED RPC
484 0 1 0 0.00% 0.00% 0.00% 0 IP SLAs ICMP Jit
485 0 1 0 0.00% 0.00% 0.00% 0 EPC WS PI suppor
486 0 1 0 0.00% 0.00% 0.00% 0 EPC WS PD suppor
487 605 1069 565 0.00% 0.00% 0.00% 0 DCM snmp dp Thre
488 0 3 0 0.00% 0.00% 0.00% 0 snmp dcm ma shim
489 52521 3535022 14 0.00% 0.00% 0.00% 0 Bulkstat-Client
490 5 10 500 0.00% 0.00% 0.00% 0 Call Home proces
491 1 1 1000 0.00% 0.00% 0.00% 0 Call Home DS
492 0 1 0 0.00% 0.00% 0.00% 0 Call Home DSfile
493 0 3 0 0.00% 0.00% 0.00% 0 EEM Policy Direc
494 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
495 0 4 0 0.00% 0.00% 0.00% 0 EEM ED CLI
496 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Counter
497 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Interface
498 0 4 0 0.00% 0.00% 0.00% 0 EEM ED IOSWD
499 0 4 0 0.00% 0.00% 0.00% 0 EEM ED None
500 0 9 0 0.00% 0.00% 0.00% 0 EEM ED OIR
501 0 18 0 0.00% 0.00% 0.00% 0 EEM ED RF
502 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP
503 0 4 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Obje
504 1 4 250 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
505 15591 644966 24 0.00% 0.00% 0.00% 0 EEM ED Timer
506 0 6 0 0.00% 0.00% 0.00% 0 EEM ED Test
507 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Config
508 1 36 27 0.00% 0.00% 0.00% 0 EEM ED Env
509 0 4 0 0.00% 0.00% 0.00% 0 EEM ED DS
510 0 6 0 0.00% 0.00% 0.00% 0 EEM ED CRASH
511 0 6 0 0.00% 0.00% 0.00% 0 EM ED GOLD
512 96016 1368713 70 0.00% 0.00% 0.00% 0 Syslog
513 0 1 0 0.00% 0.00% 0.00% 0 HA-IDB-SYNC
514 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Nf
515 0 4 0 0.00% 0.00% 0.00% 0 EEM ED Ipsla
516 0 1 0 0.00% 0.00% 0.00% 0 NGWCRP_VPLS_MW
517 4 15 266 0.00% 0.00% 0.00% 0 RBM CORE
518 1 2 500 0.00% 0.00% 0.00% 0 CTS credentials
519 11 6 1833 0.00% 0.00% 0.00% 0 VLAN Manager
520 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
521 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
522 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
523 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
524 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
525 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
526 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
527 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
528 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
529 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
530 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
531 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
532 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
533 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
534 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
535 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
536 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
537 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
538 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
539 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
540 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
541 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
542 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
543 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
544 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
545 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
546 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
547 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
548 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
549 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
550 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
551 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
552 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
553 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
554 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
555 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
556 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
557 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
558 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
559 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
560 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
561 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
562 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
563 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
564 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
565 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
566 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
567 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
568 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
569 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
570 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
571 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
572 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
573 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
574 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
575 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
576 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
577 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
578 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
579 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
580 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
581 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
582 0 1 0 0.00% 0.00% 0.00% 0 IPC ISSU Version
583 295873 2037278 145 0.00% 0.00% 0.00% 0 mdns Timer Proce
584 1 2 500 0.00% 0.00% 0.00% 0 MRIB Process
585 12358 1067927 11 0.00% 0.00% 0.00% 0 EEM Helper Threa
586 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
587 0 1 0 0.00% 0.00% 0.00% 0 OFSDN IPC
298 0 1 0 0.00% 0.00% 0.00% 0 Ethernet PM Proc
589 0 24 0 0.00% 0.00% 0.00% 0 KEYSTORE HA IPC
590 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
591 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
592 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
593 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch po
594 0 1 0 0.00% 0.00% 0.00% 0 ONEP Dispatch XD
595 0 1 0 0.00% 0.00% 0.00% 0 XOS async sync X
302 604 35362 17 0.00% 0.00% 0.00% 0 IGMPSN L2MCM
597 78 9810 7 0.00% 0.00% 0.00% 0 SSH Event handle
598 3352121 140491491 23 0.00% 0.00% 0.00% 0 IP SNMP
599 3743535 67478967 55 0.00% 0.00% 0.00% 0 PDU DISPATCHER
600 9992561 68028248 146 0.00% 0.01% 0.00% 0 SNMP ENGINE
601 0 2 0 0.00% 0.00% 0.00% 0 IP SNMPV6
602 0 1 0 0.00% 0.00% 0.00% 0 SNMP ConfCopyPro
603 43564 326231 133 0.00% 0.00% 0.00% 0 SNMP Traps
309 0 2 0 0.00% 0.00% 0.00% 0 REP BPA/EPA Proc
605 761701 33523684 22 0.00% 0.00% 0.00% 0 CLNS Input
606 125200 4742836 26 0.00% 0.00% 0.00% 0 ES-IS Routing
607 109583 4624675 23 0.00% 0.00% 0.00% 0 LISP fwd backgro
608 3623 51214 70 0.00% 0.00% 0.00% 0 DHCPD Receive
609 3301210 27017222 122 0.00% 0.00% 0.00% 0 LISP control
610 1 3 333 0.00% 0.00% 0.00% 0 IPv6 IDB
611 40396 6287233 6 0.00% 0.00% 0.00% 0 IPv6 background
612 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Address
613 5992 588916 10 0.00% 0.00% 0.00% 0 IPv6 Input
614 0 1 0 0.00% 0.00% 0.00% 0 IPv6 ND
615 2466357 140587559 17 0.00% 0.00% 0.00% 0 MLD
616 2793534 40173239 69 0.00% 0.00% 0.00% 0 ISIS Adj
617 2893836 41814611 69 0.00% 0.00% 0.00% 0 ISIS Upd
313 327032 1504950 217 0.00% 0.00% 0.00% 0 NGWC stack power
619 0 1 0 0.00% 0.00% 0.00% 0 MPLS MIB traps
620 0 3 0 0.00% 0.00% 0.00% 0 ipmcast GIR proc
621 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Access Cont
622 623869 35250404 17 0.00% 0.00% 0.00% 0 NTP
623 3026 523536 5 0.00% 0.00% 0.00% 0 DHCPD Database
624 0 12 0 0.00% 0.00% 0.00% 0 BFD debugs
625 504704 9523529 52 0.00% 0.00% 0.00% 0 DiagCard1/-1
315 4979267 14763014 337 0.00% 0.02% 0.00% 0 HTTP CORE
627 21443 2053374 10 0.00% 0.00% 0.00% 0 BFD packet stats
628 190 853 222 0.00% 0.00% 0.00% 1 SSH Process
629 138203 11838806 11 0.00% 0.00% 0.00% 0 SACRcvWQWrk5
316 351 31876 11 0.00% 0.00% 0.00% 0 MLDSN L2MCM
633 714515 31400786 22 0.00% 0.00% 0.00% 0 Inline power inc
After reloading and upgrading the firmware it is working fine. T think there is a bug on 16.9.4. Thanks!
tkarraker1
Community Member
How i have seen it explained is the lsmpi_io is only used during start up of the switch and doesn't impact the switch performance.  This is a problem that has been reported since 2012 accross platforms. Tac said dont monitor it.
LajpatSharma17601
Frequent Visitor
Frequent Visitor
i have similar issue while i am running 17.9.3 could be a bug in 17.9.3
please refer to below logs
wwqqspts02c93#sh version
Cisco IOS XE Software, Version 17.09.03
Cisco IOS Software [Cupertino], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.9.3, RELEASE SOFTWARE (fc6)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Tue 14-Mar-23 18:26 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2023 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.9.2r, RELEASE SOFTWARE (P)
wwqqspts02c93 uptime is 10 weeks, 20 hours, 5 minutes
Uptime for this control processor is 10 weeks, 20 hours, 6 minutes
System returned to ROM by Image Install at 13:59:47 UTC Wed Apr 28 2021
System image file is "flash:packages.conf"
Last reload reason: Image Install
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
AIR License Level: AIR DNA Advantage
Next reload AIR license Level: AIR DNA Advantage
Smart Licensing Status: Smart Licensing Using Policy
cisco C9300-48P (X86) processor with 1309193K/6147K bytes of memory.
Processor board ID FOC2445L8LQ
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2 TwentyFive Gigabit Ethernet interfaces
2 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
11264000K bytes of Flash at flash:.
Base Ethernet MAC Address : 40:b5:c1:11:c7:80
Motherboard Assembly Number : 73-18274-05
Motherboard Serial Number : FOC244409H9
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : C9300-48P
System Serial Number : FOC2445L8LQ
CLEI Code Number : INM2110ARC
Switch Ports Model SW Version SW Image Mode
* 1 65 C9300-48P 17.09.03 CAT9K_IOSXE INSTALL
wwqqspts02c93#sh pla
wwqqspts02c93#sh platform reso
wwqqspts02c93#sh platform resources
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource Usage Max Warning Critical State
Control Processor 3.24% 100% 90% 95% H
DRAM 6790MB(89%) 7566MB 85% 90% W
TMPFS 253MB(3%) 7566MB 40% 50% H
wwqqspts02c93#sh processes memory platform sorted location switch 1 r0
System memory: 7748556K total, 6953476K used, 795080K free,
Lowest: 745900K
Pid Text Data Stack Dynamic RSS Name
31661 91 4086376 136 4106452 4086376 pubd
5990 285130 582468 136 464 582468 linux_iosd-imag
14983 209 335812 136 78056 335812 fed main event
3235 3389 248056 136 1312 248056 confd.smp
25847 473 85496 136 4680 85496 dbm
32129 346 73048 136 368 73048 ndbmand
23269 8381 72912 136 4756 72912 fman_fp_image
6760 1669 71600 136 3372 71600 cmand
23781 179 71364 136 12856 71364 sessmgrd
25535 7433 61704 136 3368 61704 fman_rp
6144 361 52236 136 2508 52236 sif_mgr
26294 61 49416 136 224 49416 cli_agent
24046 822 47688 136 21428 47688 smand
32622 234 41776 136 296 41776 dmiauthd
24505 421 39216 136 2624 39216 repm
30607 8 38080 136 9244 38080 python3
23122 71 29088 136 1836 29088 psd
8140 213 28492 136 2224 28492 btman
13194 1671 28004 136 2140 28004 install_mgr
1 986 25504 1036 16708 25504 systemd
6378 483 25488 136 2204 25488 stack_mgr
8470 493 23964 492 3704 23964 hman
4920 472 20428 132 1800 20428 libvirtd
15014 213 20252 136 1868 20252 btman
24287 48 20172 136 1384 20172 service_mgr
7759 155 18972 136 2040 18972 lman
12376 906 18464 136 15700 18464 ncd.sh
12874 906 18228 136 15588 18228 issu_stack.sh
24966 229 18136 136 3604 18136 tms
22457 48 17968 136 1464 17968 service_mgr
18815 906 17368 136 15456 17368 issu_stack.sh
18809 906 17268 136 15456 17268 issu_stack.sh
1183 319 17100 136 384 17100 ncsshd
7323 118 16904 136 1836 16904 keyman
15396 58 16000 136 1116 16000 tamd_proc
8807 52 14088 136 1168 14088 gr_mgr
26092 122 13396 136 1328 13396 cmm
14649 906 13336 136 10448 13336 periodic.sh
24733 81 13304 136 1600 13304 plogd
9128 266 12944 136 412 12944 nif_mgr
15639 63 12604 136 1580 12604 tams_proc
617 959 12464 136 1088 12464 ncsshd_bp
17521 84 11568 136 1272 11568 epc_ws_liaison
15112 57 11328 136 836 11328 tam_svcs_esg_cf
4416 906 10536 132 7768 10536 psvp.sh
10059 906 10156 132 6884 10156 chasync.sh
192 111 10156 132 4260 10156 systemd-journal
4551 906 10080 132 6840 10080 pvp.sh
10484 906 10048 132 6684 10048 kernel_ftrace.s
4910 85 9760 132 396 9760 virtlogd
13323 906 9660 132 6224 9660 pvp.sh
31451 58 9572 136 412 9572 pttcd
17585 906 9536 132 6132 9536 reflector.sh
4876 906 9460 132 6260 9460 droputil.sh
10414 906 8356 132 6620 8356 chasync.sh
10490 906 8116 132 4808 8116 selinux_smu.sh
229 696 7244 132 1324 7244 systemd-udevd
5289 906 6468 132 3208 6468 iptbl.sh
31879 906 6060 136 3288 6060 confd-startup.s
7139 906 5104 136 3288 5104 confd-startup.s
7166 906 5040 136 3288 5040 confd-startup.s
24750 47 4860 136 1236 4860 journalctl
710 906 4388 136 1448 4388 pman
32206 906 4368 136 1444 4368 pman
31205 906 4368 136 1348 4368 pman
8385 906 4308 136 1348 4308 pman
23737 906 4292 136 1444 4292 pman
12626 906 4292 136 1340 4292 pman
25796 906 4280 136 1444 4280 pman
13839 906 4264 136 1448 4264 pman
22555 906 4256 136 1448 4256 pman
14575 906 4248 136 1448 4248 pman
24710 906 4232 136 1440 4232 pman
23977 906 4232 136 1448 4232 pman
15277 906 4232 136 1448 4232 pman
6941 906 4228 136 1336 4228 pman
24216 906 4216 136 1440 4216 pman
5319 906 4216 136 1340 4216 pman
23375 906 4212 136 1444 4212 pman
14138 906 4212 136 1340 4212 pman
8118 906 4200 136 1336 4200 pman
6374 906 4200 136 1480 4200 pman
12941 906 4188 136 1448 4188 pman
4881 906 4188 132 924 4188 oom.sh
25984 906 4160 136 1448 4160 pman
25292 906 4152 136 1448 4152 pman
760 168 4136 132 408 4136 dbus-daemon
12148 906 4132 136 1340 4132 pman
8775 906 4132 136 1476 4132 pman
31847 906 4128 136 1448 4128 pman
24460 906 4124 136 1440 4124 pman
7829 906 4124 136 1348 4124 pman
5663 906 4120 136 1348 4120 pman
25614 906 4108 136 1444 4108 pman
10073 43 4104 132 136 4104 flash-rec
31390 906 4096 136 1448 4096 pman
4650 10 4092 132 264 4092 rotee
32656 906 4080 136 1452 4080 pman
6009 906 4080 136 1336 4080 pman
30511 906 4072 136 1336 4072 pman
31624 906 4028 136 1448 4028 pman
7383 906 4028 136 1336 4028 pman
12235 10 4024 136 264 4024 rotee
31738 10 4020 136 264 4020 rotee
15068 906 4020 136 1448 4020 pman
31294 10 4016 136 264 4016 rotee
13042 10 4012 136 264 4012 rotee
12734 10 4012 136 264 4012 rotee
24099 10 4004 136 264 4004 rotee
31973 10 3984 136 264 3984 rotee
15191 10 3984 136 264 3984 rotee
14618 10 3980 136 264 3980 rotee
898 10 3976 136 264 3976 rotee
15470 10 3972 136 264 3972 rotee
10669 10 3936 132 264 3936 rotee
8270 10 3932 136 264 3932 rotee
22896 10 3924 136 264 3924 rotee
5166 10 3924 132 264 3924 rotee
23535 10 3908 136 264 3908 rotee
4506 10 3908 132 264 3908 rotee
25382 10 3904 136 264 3904 rotee
7936 10 3904 136 264 3904 rotee
5652 10 3904 136 264 3904 rotee
22780 10 3900 136 264 3900 rotee
15216 10 3896 136 264 3896 rotee
32027 10 3880 136 264 3880 rotee
24349 10 3880 136 264 3880 rotee
13518 10 3876 132 264 3876 rotee
30551 10 3872 136 264 3872 rotee
25695 10 3872 136 264 3872 rotee
5832 10 3868 136 264 3868 rotee
31516 10 3864 136 264 3864 rotee
14313 10 3864 136 264 3864 rotee
32372 10 3860 136 264 3860 rotee
24582 10 3856 136 264 3856 rotee
13264 10 3856 136 264 3856 rotee
6209 10 3856 136 264 3856 rotee
14693 10 3840 136 264 3840 rotee
12817 10 3832 136 264 3832 rotee
17933 10 3816 132 264 3816 rotee
7558 10 3816 136 264 3816 rotee
17235 10 3812 136 264 3812 rotee
8557 10 3812 136 264 3812 rotee
8895 10 3808 136 264 3808 rotee
5026 10 3808 132 264 3808 rotee
26129 10 3800 136 264 3800 rotee
25913 10 3796 136 264 3796 rotee
23868 10 3796 136 264 3796 rotee
22176 10 3796 136 264 3796 rotee
14800 10 3796 136 264 3796 rotee
6525 10 3796 136 264 3796 rotee
10705 10 3792 132 264 3792 rotee
7095 10 3788 136 264 3788 rotee
13966 10 3776 136 264 3776 rotee
24829 10 3756 136 264 3756 rotee
10241 10 3756 132 264 3756 rotee
351 10 3756 136 264 3756 rotee
5480 10 3752 132 264 3752 rotee
10061 906 3444 132 132 3444 flash_recovery.
22013 906 3176 136 1336 3176 pman
13977 906 3140 136 1468 3140 pman
17034 906 3128 136 1476 3128 pman
14443 906 3056 136 1336 3056 pman
22683 906 3044 136 1476 3044 pman
14190 906 3004 136 264 3004 sort_files_by_i
781 44 2980 132 132 2980 nfsdcld
777 39 2892 132 132 2892 rpc.idmapd
23285 906 2804 136 132 2804 stack_sntp.sh
4957 100 2672 132 132 2672 rpc.mountd
712 89 2640 132 132 2640 auditd
10096 134 2408 132 132 2408 xinetd
10094 134 2332 132 132 2332 xinetd
7962 134 2312 132 132 2312 xinetd
4960 76 2248 132 132 2248 rpc.statd
4951 134 2168 132 132 2168 xinetd
722 30 2132 132 132 2132 audispd
23302 46 2016 136 132 2016 sntp
4900 43 1872 132 132 1872 rpcbind
10377 21 1868 132 132 1868 inotifywait
4890 906 1868 132 132 1868 boothelper_evt.
18808 21 1752 136 132 1752 inotifywait
10772 21 1752 132 132 1752 inotifywait
7370 41 1696 136 132 1696 inet_gethost
7378 41 1660 136 132 1660 inet_gethost
13678 21 1648 132 132 1648 inotifywait
5268 21 1616 132 132 1616 inotifywait
7138 21 1612 136 132 1612 inotifywait
5653 21 1604 132 132 1604 inotifywait
18113 21 1600 132 132 1600 inotifywait
18813 21 1592 136 132 1592 inotifywait
4891 21 1588 132 132 1588 inotifywait
10752 21 1580 132 132 1580 inotifywait
7165 21 1576 136 132 1576 inotifywait
19368 21 1528 136 132 1528 inotifywait
18825 21 1528 136 132 1528 inotifywait
10877 21 1524 136 132 1524 inotifywait
4544 21 1520 132 132 1520 inotifywait
3304 14 1520 136 132 1520 erl_child_setup
14739 33 1512 132 132 1512 sleep
5099 33 1448 132 132 1448 sleep
14408 33 1320 136 132 1320 sleep
5127 33 1268 136 132 1268 sleep
4949 101 1176 132 132 1176 mcelog
wwqqspts02c93#sh platform software status control-processor brief
Load Average
Slot Status 1-Min 5-Min 15-Min
1-RP0 Healthy 0.24 0.28 0.26
Memory (kB)
Slot Status Total Used (Pct) Free (Pct) Committed (Pct)
1-RP0 Critical 7748556 6955016 (90%) 793540 (10%) 8010392 (103%)
CPU Utilization
Slot CPU User System Nice Idle IRQ SIRQ IOwait
1-RP0 0 3.80 0.90 0.00 95.30 0.00 0.00 0.00
1 2.09 0.89 0.00 97.00 0.00 0.00 0.00
2 1.30 0.60 0.00 98.10 0.00 0.00 0.00
3 1.50 0.60 0.00 97.89 0.00 0.00 0.00
4 3.29 0.99 0.00 95.60 0.00 0.09 0.00
5 2.20 1.10 0.00 96.70 0.00 0.00 0.00
6 2.99 0.89 0.00 96.10 0.00 0.00 0.00
7 1.20 1.00 0.00 97.80 0.00 0.00 0.00
wwqqspts02c93#sh clo
*19:20:10.844 AEST Tue Jan 2 2024
wwqqspts02c93#
Is there a DNAC appliance?
