DHCP Address for Interface
michael.buskin
Community Member
Hi Netpro,
We are currently setting up a router to get a DHCP address for a WAN interface, is there any particular option that must be enabled for this to happen ?
royalblues
Level 11
Level 11
config t
service dhcp
int
ip address dhcp
Narayan
Edison Ortiz
As Narayan indicated, ip address dhcp will obtain the IP address from DHCP server. However, if you are using the PPP encapsulation in the interface (PPPoE or PPPoA), you may need to use the ip address negotiated
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hdia_r/dia_i1h.htm#wp1184978
HTH,
__
Edison.
This interface will be supplied a address via a DOCSIS2.0 Modem, which command should I use ?
