DHCP ATTACK
sheraz butt
Level 2
Level 2
Hi All,
      I am having issue in my network 4500CORE switch with vlans and dhcp-server------>2900 access switches.
someone connect linksys router in one of access switch in the network and it act like dhcp server clients gets wrong ip address any fix to this.
johnd2310
Level 11
Level 11
You should look at enabling dhcp snooping, arp inspection and port security on your network. Have a look at the following docs:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swdynarp.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swdhcp82.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swtrafc.html
John
**Please rate posts you find helpful**
