dhcp binding shows same device twice
engineerongliss
I am trying to assign a static IP to a radar on my network. The mac address is 0100.08de.0000.00
I have the following in the running config:
ip dhcp pool radar
host 10.1.30.176 255.255.255.0
hardware-address 0100.08de.0000.00
when i enter show ip dhcp binding
the mac address shows up twice on the list
10.1.30.106  0100.08de.0000.00   aug 29 2014  automatic
10.1.30.176  0100.08de.0000.00  infinite         Manual
It appears the radar is receiving a dhcp lease rather than the static address I want it to take. I can ping the radar on 10.1.30.106 not 10.1.30.176.
Why won't the radar accept the  .176 ip?
Sandeep Sharma
The best way is to first use exclude command and then try client identifier. You can use the steps below:
ip dhcp excluded-address <ip address you are trying to get rid of the lease from>
then instead of hardware-address, try using client-identifier
ip dhcp pool STATIC
  host 10.1.130.176 /24
  Client-identifier xxxx.xxxx.xxxx
Do ipconfig /release then ipconfig /renew in command prompt and it will bind the IP to the computer's mac address. you can later do  "no ip dhcp excluded-address" to make sure the IP add held to the computer.
Or you can also try directly these commands:
ip dhcp pool STATIC
Thanks & Regards
Sandeep
Walter Astori
Can you try to use client-identifier and remove the command hardware-address ?
Client-identifier solved my issue. Many thanks
Sandeep Sharma
ip dhcp pool STATIC
ip dhcp pool STATIC
Thanks & Regards
Sandeep
