DHCP error with 6509
navinder.singh
<p>I am using 6509 core switch in which i configure dhcp pool for every vlan from this i connect 4510R using as a distribution swtch from this i connect 2960 switches as an access layer. My client machine is conneted with 2960 the issue is that some times my Pc of vlans get the Ip address and after 3 or4 days they do not get and showing error limited connectivity but i have sifficient ips for each vlan. Kindly provide the solution its critical. i am attaching the log of every switches(Core,Distribution,Access layer)</p>
<p><br />
<br />
<strong>Attachment Keywords : </strong> <br />
1) 6509.TXT <br />
2) 4510R.TXT <br />
3) 2960.TXT</p>
Yudong Wu
Level 7
Level 7
Did you enable spanning tree portfast on the access port of 2960 switch? If not, enable it to see if it makes any difference.
