Bookmark
Subscribe
884
DHCP HELPER
AnowiRico
Hello everyone,
I have a NAC solution that uses DHCP relay for device profiling and i want to configure DHCP relay on my cisco C1000 switch with the NAC IP as a secondary ip to sniff packets. how do i go about doing this
thanks
interface Vlan40
description EMPLOYEE
ip address 10.1.40.1 255.255.255.0
ip helper-address 10.1.100.100
ip helper-address 10.1.200.6
ip flow ingress
ISE profiling design guide: profiling services global configuration, probe setup, device integration (lookbookhq.com)
interface Vlan40
ip flow ingress
Thanks for your response, i would like to confirm some things
1. 10.1.100.100 does this IP represent the IP of the DHCP server?
2.10.1.200.6 and this the IP of the NAC device
correct the order is not important the interface will send packet to all ip helper-address list.
so dont worry which come first
