10-19-2011 01:18 AM - edited 03-07-2019 02:54 AM
hi,
ok so i have designed a network in packet tracer and what i want to achieve is that i want my PCs to get ips from the dhcp server. The ip configurations are already assigned but i am having trouble when it comes for pcs to get ip from dhcp server. This was an assignment for me and i wasnt able to complete it all.
Please do help me out here ppl. I am attaching the packet tracer file along with it in which u will see the IPs assigned to dhcp server and router interfaces but something is wrong with this network.
Ahmed
Solved! Go to Solution.
10-19-2011 04:00 AM
gonna send you multiple configs:
1) the dhcp server is the server on the right and it is giving out IP on the 192.168.2.0/25 subnet (dhcp-relay.pkt)
2) the dhcp server is the router and it is doing the same thing as above ( dhcp-server.pkt)
Alain.
10-19-2011 02:05 AM
Why have a dhcp server with 192.168.1.2 on the right and also the router as dhcp server?
you can get rid of some things on the router like the NAT on the interfaces and the rip process:
no router rip
int f0/0
no ip nat out
int f1/0
no ip nat in
Now for DHCP you must have a pool which is in same subnet as the router f0/0 so 192.168.2.0/25 for your PCs
And you can get rid of the other pools.
Regards.
Alain.
10-19-2011 02:27 AM
hi, alain can u send me the pkt tracer file with the updated configuration? that will be much appreciated.
thanks,
Ahmed
10-19-2011 04:00 AM
