DHCP lab issue
Andrew White
Level 2
Level 2
I'm trying to build a typology similar to my work in GNS3, I'm using routers with the NM-16ESW module for 16 switch ports.  Anyway I'm trying to get the host on the VLAN 90 switch an IP address via DHCP but it's having none of it. Core 1 and 2 are using HSRP for all our VLANs, I though the best way to add a DHCP server using a router would be to add it to both cores and using /30 subnets and advertise into OSPF and add the ip-helper address to the VLANs on each core.  Someone did suggest  making the 2 ports for the DHCP server a port channel, but I wasn't sure how I woudl configure this on the to cores.
Host 1
no ip routing
interface FastEthernet0/0
 ip address dhcp
 no ip route-cache
 duplex auto
 speed auto
90-Switch (layer 2)
no ip routing
interface FastEthernet1/0
 Description Host 1
 switchport access vlan 90
 duplex full
 speed 100
interface FastEthernet1/14
 switchport trunk native vlan 23
 switchport trunk allowed vlan 1,23,90,1002-1005
 switchport mode trunk
 duplex full
 speed 100
interface FastEthernet1/15
 duplex full
 speed 100
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan23
 ip address 192.168.23.90 255.255.255.0
Core1
interface Port-channel1
 duplex full
 speed 100
 channel-group 1 mode on
 duplex full
 speed 100
interface FastEthernet1/4
 description DHCP Server
 no switchport
 ip address 192.168.41.2 255.255.255.252
 duplex full
 speed 100
interface FastEthernet1/13
 switchport trunk allowed vlan 1,2,23,100,1002-1005
 duplex full
 speed 100
 switchport trunk allowed vlan 1,2,23,90,1002-1005
 duplex full
 speed 100
interface Vlan1
 no ip address
 shutdown
interface Vlan2
 ip address 128.101.10.69 255.255.0.0
 standby 2 ip 128.101.10.70
 standby 2 preempt
interface Vlan20
 ip address 192.168.20.253 255.255.255.0
 standby 20 ip 192.168.20.254
 standby 20 preempt
interface Vlan21
 ip address 192.168.21.253 255.255.255.0
 ip helper-address 192.168.21.1
 standby 21 ip 192.168.21.254
 standby 21 preempt
interface Vlan23
 ip address 192.168.23.253 255.255.255.0
 standby 23 ip 192.168.23.254
 standby 23 preempt
interface Vlan30
 ip address 192.168.30.253 255.255.255.0
 standby 30 ip 192.168.30.254
 standby 30 preempt
interface Vlan40
 ip address 192.168.40.253 255.255.255.0
 standby 40 ip 192.168.40.254
 standby 40 preempt
interface Vlan50
 ip address 192.168.50.253 255.255.255.0
 standby 50 ip 192.168.50.254
 standby 50 preempt
interface Vlan60
 ip address 192.168.60.253 255.255.255.0
 standby 60 ip 192.168.60.254
 standby 60 preempt
interface Vlan70
 ip address 192.168.70.253 255.255.255.0
 standby 70 ip 192.168.70.254
 standby 70 preempt
interface Vlan80
 ip address 192.168.80.253 255.255.255.0
 standby 80 ip 192.168.80.254
 standby 80 preempt
interface Vlan90
 ip address 192.168.90.253 255.255.255.0
 ip helper-address 192.168.41.1
 standby 90 ip 192.168.90.254
 standby 90 preempt
interface Vlan100
 ip address 192.168.100.253 255.255.255.0
 standby 100 ip 192.168.100.254
 standby 100 preempt
router ospf 1
 router-id 1.1.1.1
 log-adjacency-changes
 network 192.168.41.0 0.0.0.3 area 0
 network 192.168.90.0 0.0.0.255 area 0
 network 192.168.100.0 0.0.0.255 area 0
Core 2
 duplex full
 speed 100
 duplex full
 speed 100
 no switchport
 ip address 192.168.41.6 255.255.255.252
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
interface Vlan2
 ip address 128.101.10.68 255.255.0.0
 standby 2 priority 109
 standby 2 preempt
interface Vlan20
 ip address 192.168.20.252 255.255.255.0
 standby 20 priority 109
 standby 20 preempt
interface Vlan21
 ip address 192.168.21.252 255.255.255.0
 standby 21 priority 109
 standby 21 preempt
interface Vlan23
 ip address 192.168.23.252 255.255.255.0
 standby 23 priority 109
 standby 23 preempt
interface Vlan30
 ip address 192.168.30.252 255.255.255.0
 standby 30 priority 109
 standby 30 preempt
interface Vlan40
 ip address 192.168.40.252 255.255.255.0
 standby 40 priority 109
 standby 40 preempt
interface Vlan50
 ip address 192.168.50.252 255.255.255.0
 standby 50 priority 109
 standby 50 preempt
interface Vlan60
 ip address 192.168.60.252 255.255.255.0
 standby 60 priority 109
 standby 60 preempt
interface Vlan70
 ip address 192.168.70.252 255.255.255.0
 standby 70 priority 109
 standby 70 preempt
interface Vlan80
 ip address 192.168.80.252 255.255.255.0
 standby 80 priority 109
 standby 80 preempt
interface Vlan90
 ip address 192.168.90.252 255.255.255.0
 ip helper-address 192.168.41.5
 standby 90 priority 109
 standby 90 preempt
interface Vlan100
 ip address 192.168.100.252 255.255.255.0
 standby 100 priority 109
 standby 100 preempt
router ospf 1
 router-id 2.2.2.2
 network 192.168.41.4 0.0.0.3 area 0
On the host 1 if I run a "shut" , "no shut" on fa 0/0 and run DHCP debug commands on the DHCP server I get this:
*Mar  1 00:36:19.915: DHCPD: Sending notification of DISCOVER:
*Mar  1 00:36:19.915:   DHCPD: htype 1 chaddr cc0a.3714.0000
*Mar  1 00:36:19.919:   DHCPD: remote id 020a0000c0a8290100000000
*Mar  1 00:36:19.919:   DHCPD: circuit id 00000000
*Mar  1 00:36:19.919: DHCPD: DHCPDISCOVER received from client 0063.6973.636f.2d63.6330.612e.3337.3134.2e30.3030.302d.4661.302f.30 on interface FastEthernet0/0.
*Mar  1 00:36:19.919: DHCPD: Seeing if there is an internally specified pool class:
*Mar  1 00:36:19.919:   DHCPD: htype 1 chaddr cc0a.3714.0000
*Mar  1 00:36:19.919: DHCPD: there is no address pool for 192.168.41.1.
*Mar  1 00:36:19.935: DHCPD: Sending notification of DISCOVER:
*Mar  1 00:36:19.935:   DHCPD: htype 1 chaddr cc0a.3714.0000
*Mar  1 00:36:19.935:   DHCPD: remote id 020a0000c0a8290501000000
*Mar  1 00:36:19.935:   DHCPD: circuit id 00000000
*Mar  1 00:36:19.935: DHCPD: DHCPDISCOVER received from client 0063.6973.636f.2d63.6330.612e.3337.3134.2e30.3030.302d.4661.302f.30 on interface FastEthernet0/1.
*Mar  1 00:36:19.935: DHCPD: Seeing if there is an internally specified pool class:
*Mar  1 00:36:19.935: DHCPD: there is no address pool for 192.168.41.5.
17 Replies 17
Let me try this first, did it work for you if you keep OSPF and have the host setup like above?
I want to eventually add DHCP to the 100 switch to via this DHCP server and not use routers as hosts and use my virtualbox win 7 image as a host.
I'm using the 3725 switches everywhere I think, but turn off routing for the L2 switches.
I redid the lab with both switches and attached the configs (relevant output). I wasn't able to test Paul's method (only just saw the post!), but this basic config works with ip routing disabled on both routers.
Sorry for the delay, I have been away.  So you are not using 1 of the interface on the DHCP server and have removed L3?
