08-04-2014 11:07 AM - edited 03-07-2019 08:16 PM
My question is the following:
i have the next scenario (attached 4 switches with stp.)
My doubt is if its possible to do a monitoring of the blocked link between switch 3 and 2. Because we have had some problems with high latency in that link.
I know that its difficult because of the port being blocked since it would not allow any traffic. Only bpdu. also these switches are 2960.
is this possible?
thanks!
Solved! Go to Solution.
08-04-2014 02:45 PM
Carlos,
I am afraid no such monitoring is possible. The only mechanism I can think of that would actually be able to test the Layer2 connectivity and latency - which is what you want to do - would be Ethernet OAM but that one is not supported on Catalyst 2960 switches, and I doubt it will ever be (it is more of a service provider technology).
I am sorry to disappoint you.
Best regards,
Peter
08-04-2014 02:45 PM
Carlos,
Best regards,
Peter
08-05-2014 05:10 AM
Thanks Peter for taking your time to answer my question.
Best regards,
Carlos
