DHCP options
Hello
How can i configure the filename on an dhcp server what filename the router should look at the tftp server?
The dhcp option 66 only sends the ip of the tftp sever
so the router looks at
%Error opening tftp://192.168.1.30/router-confg (No such file or directory)
%Error opening tftp://192.168.1.30/ciscortr.cfg (No such file or directory)
%Error opening tftp://192.168.1.30/network-confg (No such file or directory)
%Error opening tftp://192.168.1.30/cisconet.cfg (No such file or directory)
but i would fix this to a filename i created
br
Blue_Bird
Please go through the video...
https://www.youtube.com/watch?v=hsPtoDxn01I
this video shows you how to create the appropriate Windows firewall rule to fix the error.
Best regards
******* If This Helps, Please Rate *******
M02@rt37
Hello @Raimund Schimanovits,
Use boot system command followed by the filename you want to request from the TFTP server.
boot system tftp://192.168.1.30/your-filename
Best regards
balaji.bandi
192.168.1.30 - is this your TFTP Server , then you should have configuration in the route folder for the router to pickup and config and load.
follow below guide :
https://www.cisco.com/en/US/docs/ios/12_1t/12_1t5/feature/guide/dt_dhcpa.html
BB
