Showing results forĀ
Search instead forĀ
Did you mean:Ā
DHCP: Pool with no parent?
TheTrueMc128k
When I read the status messages I find those ones:
*May 22 12:14:37.595: DHCPD: child  pool: 192.168.0.0 / 255.255.255.0 (LAN)
*May 22 12:14:37.595: DHCPD: pool LAN has no parent.
What does it mean? It's not writtent in the DHCP manual... is it a problem?
I have configured other pools to assign addresses manually based on MACs.
Thank You!
cadet alain
Could you post your dhcp config with sh run | s dhcp
Regards.
Alain
