DHCP problem number 2
moses12315
I am trying to configure a DHCP server on a Cisco router so it assigns the same ip each time to a specific PC. I use the following commands:
rea#config t
Enter configuration commands, one per line. End with CNTL/Z.
rea(config)#ip dhcp pool net10.9.9.x/24
rea(dhcp-config)#host 10.9.9.151 /24 ?
<cr>
% This command may not be used with network, origin or vrf pools.
Why i can not do that .
moses
spremkumar
Level 9
Level 9
hi moses
y cant u think off going on for manual binding based on the mac address of the clients ?
do refer this link for more options..
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804419eb.html#wp1074511
regds
ok but when i use the command host address [mask | /prefix-length], i receive the following message:
I can not proceed .
moses
dimuthurathna
When a DHCP client that has previously had a DHCP-assigned address is started again, the client goes into an INIT-REBOOT state. The client will attempt to verify that it can still use the same address by sending a DHCPRequest packet, populating the DHCP Option Field "DHCP Requested Address" with the previously assigned IP address.
