DHCP SERVER and multi-vlans
moussa.malqui1
I have a server dhcp windows server 2008 I configured 2 scopes 10.30.60.11-10.30.60.244 and 10.30.70.11-10.30.70.244 to diffuse the ip addresses in both vlans but the diffusion is done only in first vlan (VLAN2 : 10.30.60.0/24)
  My backbone switch (HP-5406Rzl2) configuration is as follows: (swith linked to a firwall ASA5512-x)
HP-5406Rzl2(config)# sh running-config
Running configuration:
; J9850A Configuration Editor; Created on release #KB.15.15.0008
; Ver #05:18.7f.ff.3f.ef:4d
hostname "HP-5406Rzl2"
module A type j9534a
module B type j9537a
ip routing
snmp-server community "public" unrestricted
oobm
no ip address
exit
vlan 1
name "VLAN1"
no untagged A1
tagged A2-A24,B1-B24
no ip address
ip helper-address 10.30.60.3
exit
vlan 2
name "VLAN2"
untagged A1                               //port lié au serveur dhcp
tagged A2-A6,A8-A10,A12-A24,B1-B24
ip address 10.30.60.1 255.255.255.0
exit
vlan 3
name "VLAN3"
tagged A2-A9,A11-A12,A14-A24,B1-B24
ip address 10.30.70.1 255.255.255.0
ip helper-address 10.30.60.3                        //adresse ip du serveur dhcp
exit
no autorun
no dhcp config-file-update
no dhcp image-file-update
where is the problem?
thanks in advance
MM
5 Replies 5
Hello
What is it question you are asking?
You seem to be showing a L3 Hp core stack with L3 interface addressing for vlan 2 and 3 but no addressing for vlan 1, And on what seems to be another switch (probably a host switch) you show no configuration?
res
Paul
Kind Regards
Paul
my question is:
the broadcast is working just for vlan 2 but not working for vlan 3. I specified the ip helper in each vlan, it must working. so where is the probably problems?
regards,
Diana Karolina Rojas
It is necesary you can provide us the configuration of the other intermediate devices to understand the cause of the problem.
rafael.alves
I am not a HP expert, but apparently the DHCP relay is not working properly. So, once DHCP server seems to be at VLAN 2, clients in VLAN2 are getting IP simply by L2 Broadcast.
Question:
The Port where you has connected your server is in mode trunk?
Remember rate the useful post, regards!
