DHCP Snooping - 1 min delay
azim1
I have issue that Windows (networking) start working in 1 minut after log in.
interface GigabitEthernet0/30
  switchport access vlan 10
 switchport mode access
 switchport voice vlan 20
 ip arp inspection limit rate 300
 storm-control broadcast level 25.00
 storm-control action shutdown
 spanning-tree portfast edge
 spanning-tree bpduguard enable
 ip dhcp snooping limit rate 10
ip dhcp snooping vlan 10,20
ip dhcp snooping information option allow-untrusted
no ip dhcp snooping information option
ip dhcp snooping database tftp:x.x.x.x
ip dhcp snooping database write-delay 15
ip dhcp snooping database timeout 15
ip dhcp snooping
ip arp inspection vlan 10,20
ip arp inspection validate src-mac
Some logs:
Jan 23 11:15:33.936: %SW_DAI-4-DHCP_SNOOPING_DENY: 2 Invalid ARPs (Req) on Gi0/30, vlan 3.([2047.47bf.91a5/10.250.5.140/0000.0000.0000/10.250.5.1/12:15:33 UTC Wed Jan 23 2019])
Jan 23 11:15:34.756: %LINK-3-UPDOWN: Interface GigabitEthernet0/30, changed state to up
Jan 23 11:15:34.936: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Gi0/30, vlan 3.([2047.47bf.91a5/10.250.5.140/0000.0000.0000/10.250.5.1/12:15:34 UTC Wed Jan 23 2019])
Jan 23 11:16:36.023: %SW_DAI-4-DHCP_SNOOPING_DENY: 1 Invalid ARPs (Req) on Gi0/30, vlan 3.([2047.47bf.91a5/10.250.5.140/0000.0000.0000/10.250.5.1/12:16:35 UTC Wed Jan 23 2019])
And after one minute everything is working.
When ip / mac are in dhcp datebase, everything is okey, but when lease time expire 1 minute delay start showing.
this is natural, or can I decrease this delay somehow ?
Hi Azim,
Yeah, its normal time before processing the request!
BR,
Tayyab - www.tayyabmunir.com
*** Please rate if the response helpful***
*** Please rate all helpful responses and mark solutions***
Mark Malone
There is a guideline of 30 seconds , its not much of a delay to fix ,  switch learns the mac, mac resolves to ip, dhcp snooping permits , take into account STP too even if only a few seconds all adds up from start to finish for access but as you seen if the fist section is already known its a lot quicker
Only timer im aware off specific to snooping is the below :
Specify (in seconds) how long to wait for the database transfer process to finish before stopping the process.
The default is 300 seconds. The range is 0 to 86400. Use 0 to define an infinite duration, which means to continue trying the transfer indefinitely.
ip dhcp snooping database timeout seconds x
