DHCP Snooping and Etherchannel config
helenio
Hello, I have a 2960 where I have gi0/1 and gi 0/2 boundled on a Channel po1. I enabled "ip dhcp snooping trust" on po1. What is trsange is that on gi0/1 and gi0/2 the command doesn't appear. What is right:
1) The command should'n appear cause is enabled only on logical interfaces PO1
2) command has to be placed manually also on gi0/1 ans gi0/2
Edison Ortiz
Commands placed under interface port-channel1 won't appear on its respective physical interfaces but commands applied to its respective physical interfaces will appear in the interface port-channel1.
