DHCP Snooping logging
Mariusz00001
I set up a simple lab and enabled dhcp snooping
PC1---F0/1--SWITCH--F0/24---DHCP Server
I added 'trust' under f0/24 and pc received an ip address, there was a dhcp snooping binding. I removed 'trust', release an ip from the pc and pc did not get an ip. that's great however the switch did NOT report anything on the screen and in the stats I cannot see any dropped dhcp messages? I tried on two Cisco switches...
Switch#sh ip dhc snooping stat det
 Packets Processed by DHCP Snooping                    = 22
 Packets Dropped Because
   IDB not known                                       = 0
   Queue full                                          = 0
   Interface is in errdisabled                         = 0
   Rate limit exceeded                                 = 0
   Received on untrusted ports                         = 0
   Nonzero giaddr                                      = 0
   Source mac not equal to chaddr                      = 0
   No binding entry                                    = 0
   Insertion of opt82 fail                             = 0
   Unknown packet                                      = 0
   Interface Down                                      = 0
   Unknown output interface                            = 0
   Misdirected Packets                                 = 0
   Packets with Invalid Size                           = 0
   Packets with Invalid Option                         = 0
Switch#sh ip dhcp snooping
Switch DHCP snooping is enabled
DHCP snooping is configured on following VLANs:
DHCP snooping is operational on following VLANs:
DHCP snooping is configured on the following L3 Interfaces:
Insertion of option 82 is disabled
   circuit-id default format: vlan-mod-port
   remote-id: 0019.e8a3.df80 (MAC)
Option 82 on untrusted port is not allowed
Verification of hwaddr field is enabled
Verification of giaddr field is enabled
DHCP snooping trust/rate is configured on the following Interfaces:
Interface                  Trusted    Allow option    Rate limit (pps)
Switch#
Switch#sh ip dhc sno sta
 Packets Forwarded                                     = 38
 Packets Dropped                                       = 0
 Packets Dropped From untrusted ports                  = 0
Switch#
PC says
C:\Users\user>ipconfig /renew
Windows IP Configuration
An error occurred while renewing interface Local Area Connection : unable to con
tact your DHCP server. Request has timed out.
No other config on the switch, just
ip dhcp snooping vlan 1
ip dhcp snooping
Have I missed sth easy here?
7 Replies 7
Mariusz00001
Any ideas please?
"Insertion of option 82 is disabled"
What is the dhcp snooping configuration that you are running?
one switch, dhcp server and pc connected to vlan 1
I meant the IOS command configuration.
Mariusz00001
I tried on a 2960 and it is the same - no logs, no stats. Any ideas please?
Mariusz00001
Switch#sh run
Building configuration...
Current configuration : 1392 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip dhcp snooping
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2,6,9,74,77
vlan 99
 name MGMT
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 ip address dhcp
ip classless
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
[b]Switch#sh ip dhcp binding[/b]
IP address       Client-ID/              Lease expiration        Type
                 Hardware address
Switch#
Switch#
Switch#sh ip dh
Switch#sh ip dhcp snooping stat
 Packets Forwarded                                     = 147
 Packets Dropped                                       = 0
[b]Switch#sh ip dhcp snooping dat[/b]
Agent URL :
Write delay Timer : 300 seconds
Abort Timer : 300 seconds
Agent Running : No
Delay Timer Expiry : Not Running
Abort Timer Expiry : Not Running
Last Succeded Time : None
Last Failed Time : None
Last Failed Reason : No failure recorded.
Total Attempts       :        0   Startup Failures :        0
Successful Transfers :        0   Failed Transfers :        0
Successful Reads     :        0   Failed Reads     :        0
Successful Writes    :        0   Failed Writes    :        0
Media Failures       :        0
PC:
An error occurred while releasing interface Loopback Pseudo-Interface 1 : The sy
stem cannot find the file specified.
ds_warwick
I know this post is very old but I also have the same issue. Were you able to resolve it?
What I have noticed in my setup (Catalyst 3750X) is that I get the same issue in a lab environment setup with the switch logging to it's local log.
If I put the switch into a more complex live setup, logging to Unix Syslog via the logging traps and logging facility global configuration commands, then I do get the events logged to my Syslog server and the statistics are incremented as expected.
It is as if the logging/statistics are bypassed if the switch is only logging locally. I'm not sure if this is a bug or by design.
