DHCP static binding on cisco switch
ajay chauhan
Level 7
Level 7
I have created this config on switch.
p dhcp pool CARLSON
   network 10.36.247.64 255.255.255.224
   domain-name carlson.com
   dns-server 203.122.63.152 203.122.63.154
   default-router 10.36.247.81
ip dhcp pool pool2
   host 10.36.247.82 255.255.255.224
   hardware-address 0100.16d3.0f1d
interface Vlan1
ip address 10.36.247.81 255.255.255.224
end
DHCP works fine but i need to map MAC addresses. I saw a doc where it was mentioned if i need to do that i need to go for special pool so i created pool2.
still the machine is getting IP address dynamic way.
Switch#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.36.247.81            -   ecc8.82f4.76c0  ARPA   Vlan1
Internet  10.36.247.67            0   0016.d30f.1db3  ARPA   Vlan1
Switch#
Can some help me what i am missing here ?
Ajay
cadet alain
Can you avoid putting the same post in different sections.
Please delete this duplicate post as it is already in the wan and routing section.
Regards.
Alain.
Hi Ajay,
Your problem will get solve by following the below steps...
Specify a new DHCP pool for each differentiated with each hardware-address
that you want to tie in.
ip dhcp pool CLIENTS
network 192.168.198.0 255.255.255.0
default-router 192.168.198.1
dns-server 192.168.200.5 192.168.199.5
domain-name example.local
lease 0 4
ip dhcp pool RESERVED-HOST
host 192.168.198.80 255.255.255.0
client-identifier 0100.4096.3944.3f
So the client with MAC 0040.9639.443f will always lease the IP
192.168.198.80/24 with the other options from the pool CLIENTS
Please rate the helpfull posts.
Naidu.
