dhcp stopped working through C4506
tsrader
users unable to connect to lan thru C4506 anymore.
no network / switchport changes made
switchports set to following:
spanningtree portfast
switchport mode access
vlan 1 is being used as default vlan
can ping dhcp server and rest of network
when users boot PC, they hang until network cable is unplugged. once they've logged in (cached credentials), network cable can be plugged back in and they work fine
issue is with this switch ONLY.....dhcp server shows no errors / events. all other users on other switches connected to same network have NO issues.
IOS: 12.2.18(EW) --- i know.....OLD. dont know if THIS would cause SUDDEN problem.
thx for any info.
Edison Ortiz
Have you tried reloading the switch ?
Kevin Dorrell
Level 10
Level 10
Are you using dot1x?
Are you running DHCP snooping or ARP inspection?
Have you checked the log? Are all ports on the 4506 on the same vlan (vlan 1)?
