DHCP won't cross the trunk
thasak
I read few threads about this issue, hovewer there is no sollution that works for me. I can ping both 10.0.0.13 or 10.0.0.14, management vlan works fine on copper, DHCP works on Fa 0/23.
Not working: device that try to connect to AP çan't aquire IP address.
Scenario:
catalyst 3750, configured dhcp server, int fa 0/24 - trunk, native vlan 10
aironet 1421 autonomous, gi0 - trunk, native vlan 10
-- 3750 config
ommited ! ip dhcp pool lan network 10.0.0.0 255.255.255.240 default-router 10.0.0.13 dns-server 8.8.8.8 domain-name int.local lease 0 4 ! -- output ommited ! interface FastEthernet0/23 # for testing purposes switchport access vlan 10 switchport mode access ! interface FastEthernet0/24 switchport trunk encapsulation dot1q switchport trunk native vlan 10 switchport trunk allowed vlan 10 switchport mode trunk ! interface GigabitEthernet0/1 ! interface GigabitEthernet0/2 ! interface Vlan1 no ip address shutdown ! interface Vlan10 ip address 10.0.0.13 255.255.255.240 !
-- aironet 1421
no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname AP ! ! logging rate-limit console 9 enable secret 5 xxxxx ! no aaa new-model no ip source-route no ip cef ip domain name int.local ! ! ! ! login block-for 60 attempts 2 within 10 login on-failure log login on-success log dot11 syslog ! dot11 ssid k2 vlan 10 authentication open authentication key-management wpa version 2 mbssid guest-mode wpa-psk ascii 7 xxxxx ! dot11 ssid k2g vlan 30 authentication open authentication key-management wpa version 2 mbssid guest-mode wpa-psk ascii 7 xxxxx ! dot11 ssid k5 vlan 10 authentication open authentication key-management wpa version 2 mbssid guest-mode wpa-psk ascii 7 xxxxx ! dot11 ssid k5g vlan 30 authentication open authentication key-management wpa version 2 mbssid guest-mode wpa-psk ascii 7 xxxxx ! ! ! no ipv6 cef ! ! username Cisco password 7 05280F1C2243 ! ! bridge irb ! ! ! interface Dot11Radio0 no ip address ! encryption mode ciphers aes-ccm ! encryption vlan 10 mode ciphers aes-ccm ! encryption vlan 30 mode ciphers aes-ccm ! ssid k2 ! ssid k2g ! antenna gain 0 mbssid speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. channel 2437 station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio0.10 encapsulation dot1Q 10 bridge-group 10 bridge-group 10 subscriber-loop-control bridge-group 10 spanning-disabled bridge-group 10 block-unknown-source no bridge-group 10 source-learning no bridge-group 10 unicast-flooding ! interface Dot11Radio0.30 encapsulation dot1Q 30 bridge-group 30 bridge-group 30 subscriber-loop-control bridge-group 30 spanning-disabled bridge-group 30 block-unknown-source no bridge-group 30 source-learning no bridge-group 30 unicast-flooding ! interface Dot11Radio1 no ip address ! encryption mode ciphers aes-ccm ! encryption vlan 10 mode ciphers aes-ccm ! encryption vlan 30 mode ciphers aes-ccm ! ssid k5 ! ssid k5g ! antenna gain 0 peakdetect no dfs band block mbssid speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. channel dfs station-role root bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio1.10 encapsulation dot1Q 10 bridge-group 10 bridge-group 10 subscriber-loop-control bridge-group 10 spanning-disabled bridge-group 10 block-unknown-source no bridge-group 10 source-learning no bridge-group 10 unicast-flooding ! interface Dot11Radio1.30 encapsulation dot1Q 30 bridge-group 30 bridge-group 30 subscriber-loop-control bridge-group 30 spanning-disabled bridge-group 30 block-unknown-source no bridge-group 30 source-learning no bridge-group 30 unicast-flooding ! interface GigabitEthernet0 no ip address duplex auto speed auto ! interface GigabitEthernet0.10 encapsulation dot1Q 10 native bridge-group 1 bridge-group 1 spanning-disabled no bridge-group 1 source-learning ! interface GigabitEthernet0.30 encapsulation dot1Q 30 bridge-group 30 bridge-group 30 spanning-disabled no bridge-group 30 source-learning ! interface BVI1 mac-address c471.fe43.c7cc ip address 10.0.0.14 255.255.255.240 ipv6 address autoconfig ipv6 enable ! ip forward-protocol nd ip http server no ip http secure-server ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag ! ! ! bridge 1 route ip ! ! ! line con 0 line vty 0 4 login local transport input all ! end
6 Replies 6
Dennis Mink
why are you using native vlan when you are explicitly tagging dot1q with vlan 10?  take the native vlan statements out if you tag all vlans.
also. if you have an endpoint with a static ip address associated with the ap, in vlan 10, can you ping the dhcp server/switch?
cheers
Please remember to rate useful posts, by clicking on the stars below.
By default switch interface is going to have this statement:
switchport trunk allowed vlan 10, 30
 I cannot remove vlan 10 native because I will lose management on AP.
I did as you recommended, I set static IP on wireless client but no luck, no access ether to AP or switch gateway. I can assume that this could be an issue with AP, but device I working fine in router-on-a-stick configuration, with vlans etc. That's why I'm surprised why it's not working, in this setup switch replaced router.
Thanks for sugestion!
update:
I'm SPANing fa0/24 interface and in wireshark all I can see is CDP and ping while I'm pinging one of the gateways.
Setting up static IP on wireless clinent and running ping doesn't work. What's more, I cannot ping AP gateway once I'm connected wirelessly.
Any ideas folks?
in addition to the other posts, I think you need to add an IP helper address to the BVI:
interface BVI1
ip helper-address 10.0.0.13
ipv6 enable
and also:
ip default-gateway 10.0.0.13
Sorry for my late response, today I made another attempt to troubleshoot that AP and I finally fixed it by erasing everything and entering line by line of my config manualy, and it works now. Thank you all for help!
Hello
Can you post that new configuration be intersting to see if you have added the following:
interface dot11radio 0.10
encapsulation dot1q vlan-id native 10
interface dot11radio 1.10
Kind Regards
Paul
Yes, thanks I added this, here is my config, all working as it should. However I have quick question, while I'm adding vlan to dot11 ssid, eg. vlan 10 to interface 2g and 5g it says that I cannot set the same vlan on more that 1 interface, when finally it's addedd to config, is it a bug?
no service pad
hostname AP
enable secret 5 xxx
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 ssid k2g
   vlan 30
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 xxx
dot11 ssid k5g
   vlan 30
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 xxx
dot11 ssid k2gee
   vlan 10
   authentication open
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 xxx
dot11 ssid k5gee
   vlan 10
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 xxx
no ipv6 cef
username xxx privilege 15 secret 5 xxx
bridge irb
 no ip address
 ssid k2g
 ssid k2gee
 antenna gain 0
 mbssid
 channel 2437
 station-role root
 bridge-group 1
 bridge-group 30
 no ip address
 ssid k5g
 ssid k5gee
 antenna gain 0
 peakdetect
 no dfs band block
 mbssid
 channel dfs
 station-role root
 bridge-group 1
 no ip address
 duplex auto
 speed auto
 bridge-group 1
 bridge-group 30
interface BVI1
 mac-address c471.fe49.c7cc
 ip address 10.0.0.61 255.255.255.192
 ip helper-address 10.0.0.62
 ipv6 address dhcp
 ipv6 enable
ip default-gateway 10.0.0.62
ip http server
bridge 1 route ip
line con 0
line vty 0 4
 password 7 xxx
 login local
 transport input ssh
end
