Difference between arp and mac address table
vishalpatil86
Level 7
Level 7
whats the difference between arp and mac address table?
can we use these terms interchangeably?
vishal
To add, a pure routers job is to forward packets based on layer 3 information. Therefore it will not have a mac-address-table. It will however have an arp table for your layer 3 to layer 2 resolution needed for encapsulating the packet to put on the wire.
6 Replies 6
InayathUlla Sharieff
Vishal,
Simple answer :
ARP table is Layer3 address to Layer2 address resolution.
MAC Address Table is Layer2 address to interface binding
Examples ref:-
Example  from "show arp". The IP address is matched to the Mac Address
Internet  192.168.200.3           3   0007.dddd.abc2  ARPA   Vlan4
Internet  192.168.200.10          6   000a.bbbb.a5ba  ARPA   Vlan4
Internet  192.168.200.17          -   0014.cccc.6c7b  ARPA   Vlan5
Internet  192.168.200.25        208   0005.aaaa.3b5a  ARPA   Vlan5
The mac-address-table Maps Mac Addresses to Physical Ports on a Switch
Example from "show mac-address-table" The Mac address is matched with the port Number.
MAC Address                                         Port the MAC was learned on
0021.d837.a6fc          Dynamic       1     FastEthernet3
0007.95dc.04c1          Dynamic       4     FastEthernet2
000a.95b0.a5aa          Dynamic       4     FastEthernet0
2)
Yes and no based on the  person understanding,
Inayath
*** Please dont forget to rate if this info is helpfull.
For your second question clearity:
The ARP table is your layer 3 to layer 2 resolution.  You examine this on your layer 3 device.
The mac-address-table is used by the switch.  It tells the switch which port to forward frames given a specific MAC address. It's the mac address to switchport resolution. The mac-address-table has nothing to do with IP addresses.
Hope this helps.
thank you soo much..
djthomassmith
Visitor
Is the MAC address table used to build the ARP table?
No, as the MAC table doesn't have IPs.
