09-03-2006 02:46 AM - edited 03-05-2019 12:02 PM
please if any one can give me the difference between NM-1CE1T1-PRI and NM-HDV2-1T1/E1
09-03-2006 03:36 AM
IP Communications High-Density Digital Voice Network Module with 1 T1/E1 -- NM-HDV2-1T1/E1
Deails:
http://www.cisco.com/en/US/products/hw/modules/ps5365/products_data_sheet09186a0080191d41.html
1-Port Channelized E1/T1/ISDN-PRI Network Module --- NM-1CE1T1-PRI
Details : http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a0080189f95.html
Hope this info helps u
Raj
09-03-2006 04:38 AM
if you want to add E1 channel for voice and you have to choose one of them without any specification added which one will you take ?
09-03-2006 05:43 AM
Hi ahmad,
I would prefer
1 T1/E1 -- NM-HDV2-1T1/E1 model for Voice
Raj
09-18-2007 01:11 AM
Hi, rajinikanth
Is NM-1CE1T1-PRI support voice with 3825 router?
Thanks, i will vote for your help
09-19-2007 09:34 PM
Hi Ahmad,
NM-1CE1T1-PRI does *not* support voice. Please refer to the following urls:
Cisco E1/T1 ISDN PRI Network Module - Data Sheet
Voice Hardware Compatibility Matrix (Cisco 17/26/28/36/37/38xx, VG200, Catalyst 4500/4000, Catalyst 6xxx)
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
Relevant Interfaces and Modules
http://www.cisco.com/en/US/products/ps5855/products_relevant_interfaces_and_modules.html
-Vaibhav
