09-19-2007 08:54 PM - edited 03-05-2019 06:35 PM
Is it possible to do HSRP on 2 pair stacked switches? (1pair stacked and 1 pair stacked)
09-19-2007 09:04 PM
Yes , You can do it.
If one pair is stacked in the sense logically it is a single switch.If you have another pair stacked in your network then you can do hsrp for redundency.
satish
09-19-2007 09:14 PM
Hi Alex,
Yes it is very well possible.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/scg1/swhsrp.htm#wp1069751
Ankur
*Pls rate all helpfull post
