Difference between "ip default-gateway" and "ip route 0.0.0.0"?
gwhuang5398
Level 2
Level 2
On the Catalyst switches, is it the same to use "ip default-gateway" or "ip route 0.0.0.0" to set a default route?
Thanks a lot
Gary
glen.grant
No a default gateway is only used if you have turned off ip routing on the L3 switch . If you have ip routing turned on you would use the static default route pointing to the next hop address.
