Different output between show running-config vs. show running-config interface vlanXX
Domz
Can anyone shed some light in the difference of show output command? My client thinks it is a Cisco bug. But I told him it is a default configuration when you create a L3 interface.
He stated like this as below:
switch shows strange behavior on displaying config when listing only displaying the running config from VLAN94, the line "no ip route-cache" is present:
Switch#sh run int vlan94
Building configuration...
Current configuration : 110 bytes
interface Vlan94
description MGMT_VL94
ip address 172.21.94.225 255.255.255.0
no ip route-cache
end
but when listing the whole running config the config line is missing:
Switch#sh run
Current configuration : 139889 bytes
......<omitted>
interface Vlan94
Can anyone who knows something about this provide an explanation? Appreciate the response.
6 Replies 6
Leo Laohoo
What firmware is the switch running on?
Version 16.12.3a
balaji.bandi
i do not see that behaviour, ( iam running near by version 16.12.2)
can you post show version,  can you check by issueing wr command ?
BB
Its not accessible now. They may have powered off the switch. What do you need from the show version output aside from the IOS-XE version?
Mark Elsen
 - Defaulted settings may be omitted from show run,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
'show running-config all' output command also doesn't show it.
